A050-006
A050-006
    TRIPPLITE
    CABLE AUDIO DUAL 6' GOLD
A050-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Audio Cables (2 x RCA M/M), 6-ft. Highlights ● Superior audio quality for movies with Dolby Digital and DTS Surround-Sound ● High-purity copper coax for improved signal transfer and low energy loss ● Double-shielded construction for maximum EMI/RFI protection ● Silver-plated center conductor for the best high frequency response MODEL NUMBER: A050-006 System Requirements ● Home Theater or Stereo equipment with RCA Digital Audio connectors Package Includes ● Description Tripp Lite's premium High Resolution Gold Audio Cables are designed to provide a clear, accurate sound, as well as eliminate noise and interference that can compromise your listening pleasure. This 6 ft. cable is specifically designed for digital devices, providing better sonic accuracy and more detailed, natural sound. This cable features 75 ohm coaxial cable, made of 99.99% pure copper, and precision machined, 6-cut, Gold RCA connectors that are corrosion resistant. Features ● Superb audio clarity with more natural sounding mid-range ● Premium-grade, 99.99% pure copper conductors ● Nitrogen-injected dielectric material delivers better high frequencies and a more realistic stereo image ● 6-cut RCA connectors, with split-tip center pin, ensure a precise connection ● 24kt gold plating resists corrosion and provides increased durability ● Molded, color coded connectors ● Abrasion resistant flexible PVC jacket Specifications OVERVIEW UPC Code 037332121899 Technology Stereo Audio PHYSICAL Color Black Cable Length (ft.) 6 Cable Length (m) 1.83 1/2 6 ft. High Resolution Gold Audio Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 9.50 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 24.13 x 17.78 x 1.27 Shipping Weight (lbs.) 0.58 Shipping Weight (kg) 0.26 CONNECTIONS Side A - Connector 1 (2) RCA (MALE) Side B - Connector 1 (2) RCA (MALE) Latching or Gripping Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
A050-006
物料型号:A050-006
器件简介:Tripp Lite的高分辨率金音频电缆设计用于提供清晰、准确的音效,同时消除可能影响听觉享受的噪音和干扰。这种6英尺长的电缆专为数字设备设计,提供更好的声音准确性和更详细、自然的声音。
引脚分配:电缆两端各有两个RCA公头连接器。
参数特性:75欧姆同轴电缆,由99.99%纯铜制成,采用精密机械加工的6切面、耐腐蚀的金RCA连接器。
功能详解:提供卓越的音频清晰度,更自然的中频声音;高级99.99%纯铜导体;注入氮气的介质材料提供更好的高频和更真实的立体声图像;24K金镀层耐腐蚀,提供增加的耐用性。
应用信息:适用于家庭影院或立体声设备,具有RCA数字音频连接器。
封装信息:黑色,6英尺长,1.83米,带有颜色编码的成型连接器,耐磨损的柔性PVC护套。
产品保修期限:全球范围内的终身有限保修。
A050-006 价格&库存
很抱歉,暂时无法提供与“A050-006”相匹配的价格&库存,您可以联系我们找货
