REVISION W
FJH-XX-X-XX.XX-X
DESIGNED & DIMENSIONED
IN MILLIMETERS
STRIP LENGTH
-4: 4MM
No OF POSITIONS
-06, -10, -15, -20, -24,
-25, -30, -40, -43, 50
(SEE TABLE 1)
DO NOT
SCALE FROM
THIS PRINT
LENGTH
-XX.XX INCHES .125 INCH
(-D & -R: 2.00 MINIMUM)
(-S: 2.50 MINIMUM)
STYLE
*-S: SINGLE ENDED
-D: DOUBLE ENDED
-R: REVERSE STIFFENER
* = AS OF 1/1/11, -S (SINGLE ENDED) AVAILABLE TO EXISTING
CUSTOMERS ONLY, ALL OTHERS WILL BE ASP`S.
0.12 S
LENGTH .125
(SEE PRODUCT DESCRIPTION AND NOTE 3)
0.30 (SEE NOTE 4)
0.10 Z S
C
C
"B"
(SEE TABLE 1)
"A"±0.06
(SEE TABLE 1)
-S0.50
4.00±0.50
(2 PLCS)
TPW-03
0.10 REF
JIF-120
0.15 REF
-Z-
FS-17
0.300±0.038
4.50±1.00
C
FIG 1
(-D=DOUBLE ENDED)
(FJH-10-D-XX.XX-4 SHOWN)
CPC
THIS SHEET
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
X.X: 0.3
X.XX: 0.05
X.XXX: 0.025
NOTE:
1. C REPRESENTS A CRITICAL DIMENSION.
2. TO BE MEASURED AT BASE OF EXPOSED LEAD.
3. ENGLISH IS PRIMARY FOR THIS MEASUREMENT.
4. TO BE MEASURED ON BOTH EDGES OF CABLE.
MATERIAL:
C5, C6, C9
ANGLES
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
CONDUCTORS: TIN PLATED COPPER
SURFACE FINISH EITHER BRIGHT TIN (99.9% SN)
OR MATTE TIN (95.5% SN, 3.5% AG, 1% CU)
INSULATION & STIFFENER: POLYESTER
F:\DWG\MISC\MKTG\FJH-XX-X-XX.XX-X-MKT.SLDDRW
SHEET SCALE: 6:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
.5mm FLEX CABLE JUMPER
FJH-XX-X-XX.XX-X
BY: KEVIN B
6/28/00
SHEET 1 OF 2
REVISION W
LENGTH .125
4.00±0.50
(2 PLCS)
FIG 2
(-R= REVERSE STIFFENER) (MACHINE BUILT)
(SAME AS FIG 1 UNLESS STATED)
CPC
THIS SHEET
PROPRIETARY NOTE
SHEET SCALE: 6:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
FJH-XX-X-XX.XX-X
BY: KEVIN B
6/28/00
SHEET 2 OF 2
很抱歉,暂时无法提供与“FJH-40-D-02.00-4”相匹配的价格&库存,您可以联系我们找货
