REVISION AC
FJ-XX-X-XX.XX-X
STRIP LENGTH
**-2: .079 [2.00]
*-4: .157 [4.00]
**-6: .236 [6.00]
No OF POSITIONS
-05, -10, -15, -20, -25, -30
DO NOT
SCALE FROM
THIS PRINT
STYLE
**-S: SINGLE ENDED
-D: DOUBLE ENDED
-R: REVERSE STIFFENER
LENGTH
-XX.XX: "XX" INCHES .125 [3.18]
(-S STYLE 2.500 [63.50] MIN)
(-D & -R STYLE 2.000 [50.80] MIN)
* = RECOMMENDED MATING WITH FC1
** = ONLY AVAILABLE TO EXISTING CUSTOMERS,
ALL OTHERS WILL BE ASP`s.
C
XX.XX[XX.X]±.125[3.18]
FC-XX-1.0
.03 0.7 REF
C
(No OF POS x .03937 [1.0000])
+.03937 [1.0000] .010[0.25]
(SEE NOTE 3)
{No OF POS x .03937 [1.0000]}
+ .03937 [1.0000] .005[0.13]
(SEE NOTE 2)
2 MAX SWAY
(EITHER DIRECTION)
C
.0256±.008 0.650±0.20
(TO BE MEASURED AT
BASE OF EXPOSED LEAD)
"C"±.015[0.38]
(SEE TABLE 1)
.013 0.32 REF
.004 0.10 REF
.207 5.26
REF
.021 0.52 REF
C
.012±.002 0.30±0.05
FIG 1
HAND BUILT
-S: SINGLE ENDED
(FJ-10-S-XX-2 SHOWN)
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. MEASURE WHERE STIFFENER AND CABLE ARE ATTACHED.
3. MEASURED ALONG LENGTH OF CABLE, EXCEPT WHERE STIFFENER
IS ATTACHED TO CABLE.
4. NOTE DELETED.
5. STIFFENER IS TRIMMED TO CORRECT WIDTH.
6. NOTE DELETED.
7. DIMENSION TO BE MEASURED IN ALL 4 CORNERS.
.005 0.13 (TYP)
CRITICAL DIMENSION INSPECTION INSTRUCTION TABLE
ASSEMBLY
IN-PROCESS INSPECTION
OPERATION
ASSEMBLY STIFFENER
C4, C5
FS-20
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.25]
2
.XXX: .005 [.13]
.XXXX: .0020 [.050]
MATERIAL:
STRIP CABLE
C3
TRIM STIFFENER
C1, C2, C6
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 4:1
CONDUCTORS: TIN PLATED COPPER
SURFACE FINISH EITHER BRIGHT ACID TIN (99.9% SN)
OR MATTE TIN (95.5% SN, 3.5% AG, 1% CU)
INSULATION: POLYESTER
STIFFENER: POLYESTER
F:\DWG\MISC\MKTG\FJ-XX-X-XX.XX-X-MKT.SLDDRW
(No OF POS -1) x .03937 [1.0000]
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.03937 [1.0000] FLEX CABLE JUMPER
DWG. NO.
FJ-XX-X-XX.XX-X
BY: KEVIN B
3/29/99
SHEET 1 OF 3
REVISION AC
FC-XX-1.0
"C"±.015[0.38]
(SEE TABLE 1)
"C"±.015[0.38]
(SEE TABLE 1)
FS-20
FOR -S: (XX.XX [XX.X] + .591 [15.16]) .050 [1.27]
FOR -D & -R: (XX.XX [XX.X] + 1.181 [30.00]) .050 [1.27]
IN-PROCESS 1
FIG 2
-D: DOUBLE ENDED
(SAME AS FIG 1, EXCEPT AS SHOWN)
SEE NOTE 5
(FIG 4 MAY BE SUBSTITUTED AT SAMTEC DISCRETION)
XX[XX]±.125[3.18]
.43 11.0
FS-20
"C"±.015[0.38]
(SEE TABLE 1)
FC-XX-1.0
FS-20
C
1.0225±.0075 25.970±0.191
"C"±.015[0.38]
(SEE TABLE 1)
.413±.030 10.49±0.76
FIG 3
(FIG 5 MAY BE SUBSTITUTED AT SAMTEC DISCRETION)
C
.2070±.0075 5.258±0.191
FS-20
.787 20.00
PROPRIETARY NOTE
IN-PROCESS 2
(TYP ON BOTH ENDS FOR -D & -R STYLES)
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
FJ-XX-X-XX.XX-X
BY: KEVIN B
3/29/99
SHEET 2 OF 3
REVISION AC
MACHINE BUILT PRODUCT
LENGTH (SPECIFY IN -XX INCHES
.125)
.03 0.7 REF
C "A"
(SEE NOTE 2)
(SEE TABLE 2)
C
.0256±.006 0.650±0.15
(TO BE MEASURED AT
(SEE NOTE 7)
"C"±.030[0.76]
(2 PLCS) (SEE TABLE 3)
JIF-XX
TPW-07
FS-XX
C "B"
(SEE TABLE 2)
.012±.002 0.301±0.05
C
.098±.039 2.48±0.99
.006 0.142 REF
FIG 4
-D: DOUBLE ENDED
(FJ-10-D-XX.XX-4 SHOWN)
FS-XX
FIG 5
(SAME AS FIG 4, EXCEPT AS SHOWN)
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
FJ-XX-X-XX.XX-X
BY: KEVIN B
3/29/99
SHEET 3 OF 3
