FFSD-05-D-16.00-01-N
    SAMTEC(申泰)
    .050X.050C.L.FEMALEIDCASSY
FFSD-05-D-16.00-01-N 数据手册
REVISION AU NOTES: 1. HIDDEN LINES ARE USED TO SHOW POLARIZATION WHEN USING -N OPTION. 2. C REPRESENTS A CRITICAL DIMENSION. 3. FFSD CABLE ASSEMBLIES ARE LEAD FREE. 4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS. C 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 630V. 6. STRAIN RELIEF TO WITHSTAND 5LB[22N] STRAIGHT PULL. No OF POSITIONS 7. NOTE DELETED. -02 THRU -25 8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND (PER ROW) PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE END ASSEMBLY THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. -S: SINGLE END 9. REFERENCE FFSD-XX-XX-X-N-XXX FOR CONNECTOR ASSEMBLY -D: DOUBLE END DIMENSIONS AND ITS REQUIREMENTS. C 10. COLORED WIRE MUST MATCH FIRST POSITION INDICATOR ASSEMBLY LENGTH ON THE FIRST CONNECTOR FOR ALL OPTIONS WITH THE (INCLUDES ADDED OPTION LENGTHS) EXCEPTION OF -RW. ALL OPTIONS THAT USE -D"XX": 4.00 [101.6] MINIMUM 11. FOR LENGTHS LESS THAN 12.5", TOLERANCE SHALL BE +/-.125, ALL OTHER OPTIONS: 1.00 [25.4] MINIMUM ALL OTHER LENGTHS SHALL BE +/-1%. FFSD-XX-X-XX.XX-01-X-X-XXX DO NOT SCALE FROM THIS PRINT OPTION -RW: REVERSE WIRING (NOT AVAILABLE WITH -RN1 OR -RN2) -D"XX": DAISY CHAIN (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) -R: REVERSED (-D"XX" OPTIONAL) (NOT AVAILABLE WITH -M OR -O) -RN1: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN2) -RN2: REVERSE POLARIZATION NOTCH (NOT AVAILABLE WITH -RW OR -RN1) -M: MIDDLE REVERSE (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -O) -O: OUTSIDE REVERSE (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -M) -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, OR -D"XX") (SOLD AS ASSEMBLIES ONLY) LEAD STYLE PLATING OPTIONS - LEAVE BLANK FOR STANDARD, USE C-67-L: 10µ" GOLD IN CONTACT AREA TIN IN IDC AREA -S: USE C-67-S: 30µ" GOLD IN CONTACT AREA TIN IN IDC AREA -F: USE C-67-F: 3µ" GOLD IN CONTACT AREA TIN IN IDC AREA C XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) STANDARD POLARIZATION NOTCH -N: POLARIZATION NOTCH (NOT AVAILABLE IN -02 THRU -04) (LEAVE BLANK FOR -02, -03, -04) .075 1.91 REF .120 3.05 REF C (No OF POS x .050[1.27]) + .165[4.19] .006 0.15 MAX +.006 XX.XX[XX.X x 25.4]±1% (SEE NOTE 8 & 11) FLUSH TO .010 0.25 MAX CABLE OVERHANG (SEE NOTE 8) 2 RED WIRE TO SIDE OF FIRST POS INDICATOR -N OPTION +0.15 C .200 - .003 5.08 - 0.08 -N OPTION 1 .040 1.02 REF FIG 2 (FFSD-10-S-XX.XX-01-X-N SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) NOTCH DENOTES FIRST POSITION FIG 1 (FFSD-10-D-XX.XX-01-X-N SHOWN) RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR THIS DOCUMENT CONTAINS CONFIDENTIAL AND TOLERANCES ARE: MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: FIG 11 (FFSD-10-X-XX.XX-01-X-N-RW SHOWN) F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW PROPRIETARY NOTE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. * * PROPRIETARY INFORMATION AND ALL DESIGN, AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 INSULATORS: PBT UL94V-0, COLOR: BLACK CONTACT: BeCu WIRE: 30 AWG, 7/38, TINNED, STRANDED WITH GRAY PVC INSULATOR PLATING: .000010 GOLD OVER .000050 NICKEL REMAINDER: .000200 REF TIN OVER .000050 NICKEL DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 1 OF 5 REVISION AU FIRST CONNECTOR, FIRST POSITION INDICATOR SECOND CONNECTOR, FIRST POSITION INDICATOR 03 01 02 FIRST POSITION INDICATOR (FFSD-10-S-XX.XX-01-X-N-RN1 SHOWN) (SAME AS FIG 2, DIFFERENT AS SHOWN) SECOND CONNECTOR, FIRST POSITION INDICATOR FIRST CONNECTOR, FIRST POSITION INDICATOR (FFSD-10-D-XX.XX-01-X-N-RN2 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (FFSD-10-D-XX.XX-01-X-N-RN1 SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) FIG 3 (FFSD-10-X-XX.XX-01-X-N-RNX SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (REVERSE NOTCH NOT AVAILABLE WITH -RW OR ANY DAISY CHAIN OPTIONS) -RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY (NOT AVAILABLE WITH -R OPTION) -RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY (NOT AVAILABLE WITH -R OPTION) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 2 OF 5 REVISION AU WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") MIDDLE CONNECTOR REVERSED WHEN DAISY CHAINED OUTSIDE CONNECTOR REVERSED WHEN DAISY CHAINED FIG 4 (FFSD-10-D-XX.XX-01-X-N-DXX-O SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) FIG 5 (FFSD-10-D-XX.XX-01-X-N-DXX-M SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIRST POSITION INDICATOR XX.XX[XX.X x 25.4] .13[3.2] (MIN 2") FIG 7 (FFSD-10-D-XX.XX-01-X-N-DXX SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, BOTH CONNECTORS REVERSED WHEN DAISY CHAINED INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY FIG 6 OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. (FFSD-10-D-XX.XX-01-X-N-DXX-R SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (NOT AVAILABLE WITH -RN1 OR -RN2 OPTION) (2.00[50.8] MINIMUM, 1.00[25.4] INCREMENTS) DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 3 OF 5 WITH -RW OPTION ONLY: RED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR REVISION AU (No OF POS x .050[1.27]) C + .315[8.00] REF XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] IN-PROCESS 1 (2-15 POS -SR ONLY FOR DOUBLE END) 4 .039 0.99 .335±.010 8.51±0.25 3 C (XX.XX[XX.XX x 25.4] ± .13[3.2]) C (XX.XX[XX.XX x 25.4] .13[3.2] FIG 9 IN-PROCESS 2 STRAIN RELIEF OPTION (POS 2-15 ONLY) (FFSD-10-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 1, DIFFERENT AS SHOWN) (2-15 POS -SR ONLY FOR DOUBLE END) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 1 (16-25 POS -SR ONLY FOR DOUBLE END) C XX.XX[XX.XX x 25.4] .13[3.2] IN-PROCESS 2 +0.05 .0228+-.002 .000 0.58 0.00 (16-25 POS -SR ONLY FOR DOUBLE END) DETAIL 'A' SCALE 8 : 1 6 IN-PROCESS 3 (16-25 POS -SR ONLY FOR DOUBLE END) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, 'A' MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS 5 WRITTEN CONSENT OF SAMTEC, INC. FIG 10 STRAIN RELIEF OPTION (POS 16-25 ONLY) (FFSD-25-D-XX.XX-01-X-N-SR SHOWN) (SAME AS FIG 9, DIFFERENT AS SHOWN) SCALE 1 : 1 DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 4 OF 5 REVISION AU (XX.XX[XX.XX x 25.4] ± .125[3.18]) XX.XX[XX.XX x 25.4] +.4375[11.113] .125[3.18] IN-PROCESS 1 IN-PROCESS 1 (FFSD-XX-S-XX.XX-01-X-N-RW ONLY) (16-25 POS -SR ONLY FOR SINGLE END) XX.XX[XX.XX x 25.4] .125[3.18] C XX.XX[XX.X x 25.4] + .4375[11.113]±.125[3.18] IN-PROCESS 1 IN-PROCESS 2 (2-15 POS -SR ONLY FOR SINGLE END) (16-25 POS -SR ONLY FOR SINGLE END) IN-PROCESS 3 (16-25 POS -SR ONLY FOR SINGLE END) (XX.XX[XX.XX x 25.4] ± .125[3.18]) C * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS IN-PROCESS 2 AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE (2-15 POS -SR ONLY FOR SINGLE END) 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2.5:1 F:\DWG\MISC\MKTG\FFSD-XX-X-XX.XX-01-X-X-XXX-MKT.SLDDRW DESCRIPTION: .050 x .050 DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. FFSD-XX-X-XX.XX-01-X-X-XXX BY: T NEWTON 02/15/2008 SHEET 5 OF 5
1. 物料型号:FFSD-XX-X-XX.XX-01-X-X-XXX 2. 器件简介:文档中没有提供具体的器件简介,但提到了该电缆组件是无铅的,并且所有组装件都需要进行100%的电气测试以检测短路和断路,以及100%的高压测试。 3. 引脚分配:文档中提到了不同配置的引脚数量,例如从-02到-25每排的引脚数量,以及单端和双端组装。 4. 参数特性:包括电缆长度的最小值、引脚的镀金选项、以及电缆的测试要求等。 5. 功能详解:文档中提供了不同选项的功能描述,如极性缺口、反向布线、中间反向和外部反向等。 6. 应用信息:文档中没有明确提供应用信息,但根据组件的测试和规格,可以推断它适用于需要电气连接和信号完整性的应用。 7. 封装信息:文档中提供了详细的封装尺寸和公差,以及材料规格,如绝缘体材料PBT UL94V-0,接触材料BeCu,以及电线规格30 AWG,7/38,镀锡,带有灰色PVC绝缘体。
FFSD-05-D-16.00-01-N 价格&库存
很抱歉,暂时无法提供与“FFSD-05-D-16.00-01-N”相匹配的价格&库存,您可以联系我们找货
