A02SUR02SUR32W152B
A02SUR02SUR32W152B
    JST
    JUMPER 02SUR-32S - 02SUR-32S 6"
A02SUR02SUR32W152B 数据手册
3 CONNECTOR PART NO. 2 IPI CHECK DESCRIPTION 1 See Table 1 SUR CONNECTOR 2 UL11136, 32 AWG WHITE 1 EOR CHECK Applicable Tooling BCD TABLE 1 ITEM 1 1 1 1 1 1 1 1 1 1 1 1 1 1 D NUMBER OF CIRCUITS 2 3 4 5 6 8 10 12 14 15 16 17 20 22 CONNECTOR PART NO. 02SUR-32S 03SUR-32S 04SUR-32S 05SUR-32S 06SUR-32S 08SUR-32S 10SUR-32S 12SUR-32S 14SUR-32S 15SUR-32S 16SUR-32S 17SUR-32S 20SUR-32S 22SUR-32S ASSEMBLY PART NUMBER A02SUR02SUR32W152B A03SUR03SUR32W152B A04SUR04SUR32W152B A05SUR05SUR32W152B A06SUR06SUR32W152B A08SUR08SUR32W152B A10SUR10SUR32W152B A12SUR12SUR32W152B A14SUR14SUR32W152B A15SUR15SUR32W152B A16SUR16SUR32W152B A17SUR17SUR32W152B A20SUR20SUR32W152B A22SUR22SUR32W152B TOTAL WIRE REQUIRED 304.8 mm 457.2 mm 609.6 mm 762 mm 914.4 mm 1,219.2 mm 1,524 mm 1,828.8 mm 2,133.6 mm 2,286 mm 2,438.4 mm 2,590.8 mm 3,048 mm 3,352.8 mm C D C (158.2 +/- 3.0) 152.4 +/- 3.0 1 1 PIN 1 PIN 1 0.8 THIS DRAWING CONTAINS INFORMATION THAT IS PROPRIETARY TO J.S.T. AND SHALL NOT BE USED OR SHOWN WITHOUT WRITTEN PERMISSION. 4 ITEM 2 B B Electrical Specifications Current: 0.5A AC/DC Voltage: 30V DC SCALE 1: 1 DIMENSIONS CUSTOMER NAME All dimensions are in MM with a tolerance of +/- 3.0 unless otherwise specified. A DRAWN BY 1 Add electrical specifications REV. 6/27/2018 DESCRIPTION 4 DATE 3 SP A DESCRIPTION 0.8 mm Pitch SUR Standard Catalog Assembly - 6" Overall Len gth – Pin out: 1 to N ASSEMBLY PART NO. STEVEN PILKINGTON BY CUSTOMER PART NO. CHECK ED BY SEE TABLE 1 DRAWING NO. & REVISION JUSTIN BAKER 2 REVISED GAM-008 2/25/2016 1
A02SUR02SUR32W152B 价格&库存
很抱歉,暂时无法提供与“A02SUR02SUR32W152B”相匹配的价格&库存,您可以联系我们找货
A02SUR02SUR32W152B
    库存:17
    A02SUR02SUR32W152B
      库存:1269
