P556-010
P556-010
    TRIPPLITE
    P556-010
P556-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI to VGA High-Resolution Adapter Cable with RGB Coaxial (DVI-A to HD15 M/M), 10 ft. (3.1 m) Highlights ● Connects a DVI-I port on a computer to a monitor with a VGA connector or a VGA port on a computer to a monitor with a DVI-I connector ● Compatible with Flat-Panel Displays, Digital CRT Displays and Projectors ● Supports analog signals only ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● Meets DVI DDWG Standard MODEL NUMBER: P556-010 System Requirements ● PC with DVI-I connector, and Monitor with SVGA (HD15F) connector Package Includes Allows connection of a DVI-I Video port to a VGA Monitor or a VGA Video port to a DVI-I Monitor 10-ft. (3.05 m), DVI-I MAle to VGA Male Adapter Cable Description Tripp Lite's 10-ft. (3.05 m) DVI to HD15 cable allows PC users with a DVI-I port to connect to monitors with a VGA connector or PC users with a VGA port to connect to monitors with a DVI-I connector. Goldplated contacts ensure excellent conductivity, while double shielding (foil and braid) provides maximum EMI/RFI protection. Both the DVI and HD15 connectors are molded and have integral strain relief for long life reliability. Features ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Constructed from mini-coax (RGB) and paired video wire construction for superior signal quality ● Gold plated copper contacts ensure excellent conductivity ● DVI Male to HD15 Male molded connectors ● PC and Mac compatible ● Meets DVI DDWG Standard ● Supports analog signal only Specifications OVERVIEW UPC Code 037332170163 Product Type Passive Cable Technology DVI; VGA/SVGA Cable Type Passive PHYSICAL 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Shipping Dimensions (hwd / in.) 10.00 x 8.00 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 20.32 x 1.27 Shipping Weight (lbs.) 0.66 Shipping Weight (kg) 0.30 CONNECTIONS Side A - Connector 1 DVI-A (MALE) Side B - Connector 1 HD15 (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P556-010 价格&库存
很抱歉,暂时无法提供与“P556-010”相匹配的价格&库存,您可以联系我们找货
P556-010
  • 1+138.011931+17.81462
  • 10+117.2636110+15.13642
  • 25+109.9195925+14.18845
  • 50+104.6716950+13.51105
  • 100+99.67850100+12.86653
  • 250+93.44258250+12.06159
  • 500+89.24193500+11.51937
库存:12
