CAB-10087
CAB-10087
    SPARKFUNELECTRONICS
    CAB-10087
CAB-10087 数据手册
OBD-II to DB9 Cable C A B - 1 0 0 8 7 R OH S   images are CC BY-NC-SA 3.0 Description: Once you’ve hacked everything, why not go out in the garage and hack your car? This cable allows you to access the pins on your car’s OBDII connector. It has an OBDII connector on one end and a DB9 female serial connector on the other. The overall length of the cable is 5'. Note: This cable is not meant to be plugged directly into a computer’s serial port. It is meant to plug into some sort of hardware interface. Here is the basic pinout (OBDII > DB9 Female) Pin Description OBDIIDB9 J1850 BUS+ 2 7 Chassis Ground 4 2 Signal Ground 5 1 CAN High J-2284 6 3 ISO 9141-2 K Line7 4 J1850 BUS10 6 CAN Low J-2284 14 5 ISO 9141-2 L Line 15 8 Battery Power 16 9 https://www.sparkfun.com/products/10087 10/22/2015
CAB-10087 价格&库存
很抱歉,暂时无法提供与“CAB-10087”相匹配的价格&库存,您可以联系我们找货
