SparkFun Hydra Power Cable - 6ft
C A B - 1 1 5 7 9 R OH S
images are CC BY-NC-SA 3.0
Description: Behold, the Hydra! This USB power cable probably looks a lot like
something you’ve hacked together before. We do it all the time, because what is a
computer if not a 5V power supply that happens to run software?
The Hydra brings the 5V and GND lines from your USB power supply, computer or
otherwise, and breaks those lines out into three common power connectors: Barrel
Plug, JST and Alligator Clips! The clips are shrouded to avoid shorts and the barrel
plug is center positive. The cable is 6 feet long overall which give you plenty of room
to work.
Remember that USB power does have its limitations. Most USB hosts will only
provide between 100 and 500mA at 5VDC.
Dimensions: 6' Long
https://www.sparkfun.com/products/11579
10/8/2015
很抱歉,暂时无法提供与“CAB-11579”相匹配的价格&库存,您可以联系我们找货
