P581-006
P581-006
    TRIPPLITE
    P581-006
P581-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to DVI Adapter Cable (DP with Latches to DVI-D Single Link M/M), 6 ft. (1.8 m) MODEL NUMBER: P581-006 Highlights ● DisplayPort Male to DVI-D Male, 6-ft. (1.83 m) ● Single-link adapter with latches ● Molded ends ● 1080p resolution ● Passive adapter requires the connected computer have DP++ (DisplayPort ++) dual-mode port System Requirements ● Not for use with MST Hubs. For compatibility with MST Hubs, use a DisplayPort 1.2 compliant product such as P581-006-V2 Package Includes ● Description The P581-006 DisplayPort to DVI-D Cable Adapter (M/M) allows you to connect a computer with a DisplayPort connection to a high-definition television or monitor with a DVI input. Digital video signals are passed through with full 1080p video resolution. Fully molded ends are designed to last a long time. The 6-ft. (1.83 m) P581-006 is a passive adapter that requires the host computer to have a DP++ dualmode connector, which allows HDMI and DVI signals to be passed through. Check your computer's documentation for compatibility. Features ● DisplayPort Male to DVI-D Male, 6-ft. (1.83 m) ● Single-link adapter with latches ● Molded ends ● 1080p resolution ● Passive adapter requires the connected computer have DP++ (DisplayPort ++) dual-mode port Specifications OVERVIEW UPC Code 037332148032 Product Type Passive Cable Technology DVI; DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) 1/3 DisplayPort to DVI-D Cable Adapter, Single-Link Adapter with Latches (M/M), 6-ft. (1.83 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 ENVIRONMENTAL Operating Temperature Range 32° to 158°F (0° to 70°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Connector Plating Nickel Contact Plating Gold Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS IP68 Rated No Displayport Specification 1.2 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P581-006 价格&库存
很抱歉,暂时无法提供与“P581-006”相匹配的价格&库存,您可以联系我们找货
