P137-06N-HDMI
P137-06N-HDMI
    TRIPPLITE
    MINI DISPLAYPORT HDMI ADAPTER 6"
P137-06N-HDMI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort to HDMI Adapter Cable (M/F), 6 in. (15.2 cm) MODEL NUMBER: P137-06N-HDMI Highlights ● Lets you use your current HDMI display without the expense of a new mDP monitor ● Delivers HD picture quality at resolutions up to 1920 x 1200 (1080p) ● Also converts mDP audio to HDMI for complete audio/video transmission ● Slim-profile unit fits easily into briefcase or laptop bag for instant use anywhere ● Plug-and-play operation with no software required for easy, immediate installation Applications Mini DisplayPort to HDMI adapter connects a laptop or notebook with a Mini DisplayPort or Thunderbolt 1 or 2 output to an HDMI display. Features Mini DisplayPort to HDMI Adapter Connects Your mDP Laptop to an HDMI DisplayThis Keyspan® passive Mini DisplayPort to HDMI cable connects an HDMI monitor, projector or television to the mDP or Thunderbolt 1 or 2 port on your computer, laptop, notebook, MacBook, Chromebook, Ultrabook, Microsoft Surface or other compatible computer or tablet. It features male mDP and female HDMI connectors, so you can continue using your existing HDMI display and cable to transmit audio/video without the expense of a new mDP display. Supports High-Definition 1080p and Audio for Video PresentationsThis adapter is ideal for giving video presentations in conference rooms and classrooms or playing video for digital signage in crystalclear 1080p. It supports video resolutions up to 1920 x 1080, as well as HDCP 2.2. It also transmits audio, as long as the mDP source device also does (check your source device’s manual for audio compatibility). The passive adapter requires the source device to support DisplayPort++, which allows the HDMI signal to pass through (again, check the manual for compatibility). Plug-and-Play Operation Lets You Begin Watching Video Almost ImmediatelyThe plug-and-play Mini DisplayPort to HDMI adapter requires no software, drivers or external power; works with both Windows and Mac operating systems; and is compatible with laptops, tablets and other devices equipped with a female Mini DisplayPort or Thunderbolt 1 or 2 port. The slim-profile unit is easy to carry in a pocket, purse, backpack or laptop bag for instant 1080p video where needed. ● Connect a laptop or notebook computer to an HDMI projector in an auditorium or lecture hall for a video presentation ● Extend your MacBook or Chromebook’s display to a secondary HDMI monitor for viewing on both simultaneously ● Stream digital signage messages from a computer to an HDMI display in a lobby, bar or restaurant System Requirements ● Compatible with Windows 10 and Mac 10.11 and later ● Source device with Mini DisplayPort or Thunderbolt 1 or 2 output ● Display device with HDMI input ● Audio transmission supported as long as the source device also supports it ● Source device must have DisplayPort++ to allow HDMI signals to pass through ● Not for use with MST hubs ● Please check your source device’s manual for audio and DP++ compatibility Package Includes ● 1/3 P137-06N-HDMI Mini DisplayPort to HDMI Adapter Cable, 6 in. 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332171115 Product Type Passive Cable Technology HDMI; DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) PHYSICAL Color White Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.15 Shipping Weight (kg) 0.07 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Relative Humidity 0% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HDMI (FEMALE) STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P137-06N-HDMI
物料型号:P137-06N-HDMI
器件简介:Mini DisplayPort到HDMI适配器线缆(公/母),6英寸(15.2厘米),TAA认证。
它允许您在不更换新的Mini DisplayPort显示器的情况下使用现有的HDMI显示器。
引脚分配:侧A-连接器1为Mini DisplayPort(公),侧B-连接器1为HDMI(母)。
参数特性: - 最大支持视频分辨率:1920x1200(1080p) - 连接类型:Mini DisplayPort(公)转HDMI(母) - 物理特性:白色PVC外皮,VW-1等级,线缆长度为6英寸(15.24厘米) - 工作温度范围:32°至104°F(0°至40°C) - 存储温度范围:33°至122°F(-15°至50°C) - 相对湿度:0%至85%,非凝结
功能详解:该适配器支持高达1920x1200(1080p)的视频分辨率,并且可以将Mini DisplayPort音频转换为HDMI,实现完整的音视频传输。
它支持即插即用操作,无需软件,与Windows和Mac操作系统兼容。
应用信息:适用于连接笔记本电脑或平板电脑到HDMI投影仪、显示器或电视,用于视频演示或数字标牌信息流。
封装信息:产品封装为白色,线缆长度为6英寸(15.24厘米),采用PVC材料,符合VW-1阻燃等级。
产品保修期为3年有限保修。
P137-06N-HDMI 价格&库存
很抱歉,暂时无法提供与“P137-06N-HDMI”相匹配的价格&库存,您可以联系我们找货
