P504-015
P504-015
    TRIPPLITE
    P504-015
P504-015 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States VGA High-Resolution RGB Coaxial Cable with Audio (HD15 and 3.5mm M/M), 15 ft. (4.57 m) MODEL NUMBER: P504-015 Highlights ● Superior molded cables with foilshielding for maximum EMI/RFI protection ● VW-1 and CM Rated Jacketing ● 3.5mm Stereo Plugs Package Includes ● Description Tripp Lite's 15-ft. (4.57 m) PVC SVGA/VGA monitor replacement cable features built-in 3.5mm stereo plugs, for extending audio as well video. The mini-coax (RGB) and paired video wire construction delivers superior video signal quality. Nickel plated connectors and gold plated copper contacts ensure excellent conductivity. Double shielding (foil and braid) provides maximum EMI/RFI protection. Both high density DB15 male connectors are molded and have integral strain relief to ensure they last a long time. Features ● Extend both video and audio signals 15-ft. (4.57 m) ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Constructed from mini-coax (RGB) and paired video wire construction for superior signal quality ● HD15 male to HD15 male and 3.5mm to 3.5mm molded connectors ● Computer side Audio Pigtail: 8in Display side Audio Pigtail: 24in ● VW-1 and CM Rated Jacketing Specifications OVERVIEW UPC Code 037332160065 Product Type Passive Cable Technology Coax; VGA/SVGA; Stereo Audio Cable Type Passive PHYSICAL Color Black 1/2 SVGA/VGA Monitor Cable (HD15M to HD15M w/Built-in 3.5mm Audio connectors) - 15ft. (4.57 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Black Cable Length (ft.) 15 Cable Length (m) 4.57 Cable Length (in.) 180 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.96 Shipping Weight (kg) 0.44 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 3.5MM (MALE) Side B - Connector 1 HD15 (MALE) Side B - Connector 2 3.5MM (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P504-015
1. 物料型号: - 型号编号:P504-015
2. 器件简介: - 该产品为VGA高分辨率RGB同轴电缆,带有音频(HD15和3.5mm公对公),长度为15英尺(4.57米)。
3. 引脚分配: - 侧A和侧B均配置有HD15(公)和3.5MM(公)连接器。
4. 参数特性: - 产品类型:被动电缆 - 技术:同轴;VGA/SVGA;立体声音频 - 电缆类型:被动 - 颜色:黑色 - 电缆长度:15英尺(4.57米) - 运输尺寸:9.00x7.00x0.50英寸 - 运输重量:0.96磅(0.44千克) - 产品合规性:符合RoHS标准
5. 功能详解: - 该电缆可延长音频和视频信号至15英尺(4.57米)。 - 使用箔屏蔽的优越模具电缆,以实现最大的EMI/RFI保护。 - 由mini-coax(RGB)和配对视频线构造,提供优越的视频信号质量。 - 镀镍连接器和镀金铜接触点确保优秀的导电性。 - 双屏蔽(箔和编织)提供最大的EMI/RFI保护。 - 两个高密度DB15公头都是模塑的,并且具有集成的抗拉设计,以确保它们持久耐用。
6. 应用信息: - 适用于SVGA/VGA监视器的更换电缆,内置3.5毫米立体声插头,用于扩展音频和视频。
7. 封装信息: - 电缆长度为15英尺(4.57米),带有HD15公头到HD15公头和3.5mm到3.5mm的模塑连接器。
P504-015 价格&库存
很抱歉,暂时无法提供与“P504-015”相匹配的价格&库存,您可以联系我们找货
