P556-006
P556-006
    TRIPPLITE
    P556-006
P556-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI to VGA High-Resolution Adapter Cable with RGB Coaxial (DVI-A to HD15 M/M), 6 ft. (1.8 m) Highlights ● Connects a DVI-I port on a computer to a monitor with a VGA connector or a VGA port on a computer to a monitor with a DVI-I connector ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Supports Analog signals only ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● Meets DVI DDWG Standard MODEL NUMBER: P556-006 System Requirements ● Monitor or Projector with DVI-I connector, and PC with SVGA (HD15F) connector Package Includes ● Allows connection of a DVI-I Video port to a VGA Monitor or a VGA Video port to a DVI-I Monitor Description Tripp Lite's 6-ft. (1.83 m) DVI to VGA cable allows PC users with a DVI-I port to connect to monitors with a VGA connector or PC users with a VGA port to connect to monitors with a DVI-I connector. Gold plated contacts ensure excellent conductivity, while double shielding (foil and braid) provides maximum EMI/RFI protection. Both the DVI and HD15 connectors are molded and have integral strain relief for long life reliability. Features ● Superior molded cables with foil-shielding for maximum EMI/RFI protection ● Constructed from mini-coax (RGB) and paired video wire construction for superior signal quality ● Gold plated copper contacts ensure excellent conductivity ● DVI-A Male to HD15 Male molded connectors ● PC and Mac compatible ● Meets DVI DDWG Standard ● Supports analog signal only Specifications OVERVIEW UPC Code 037332120724 Product Type Passive Cable Technology DVI; VGA/SVGA Cable Type Passive PHYSICAL 1/2 DVI-A Male to HD15 Male, 6-ft. (1.83 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.54 Shipping Weight (kg) 0.24 CONNECTIONS Side A - Connector 1 DVI-A (MALE) Side B - Connector 1 HD15 (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P556-006
物料型号为P556-006,这是一款DVI到VGA高分辨率适配器线,长度为6英尺(1.8米)。
该产品主要用于连接具有DVI-I端口的计算机到具有VGA连接器的显示器,或者将具有VGA端口的计算机连接到具有DVI-I连接器的显示器。
器件简介: 这款适配器线支持模拟信号,采用优质的模制电缆,内外双层屏蔽(箔和编织层)以提供最大的电磁干扰/射频干扰保护,符合DVI DDWG标准。
引脚分配: - 侧A连接器:DVI-A(公头) - 侧B连接器:HD15(公头)
参数特性: - 产品类型:被动线缆 - 技术:DVI;VGA/SVGA - 物理特性:黑色PVC外皮,VW-1等级,线长6英尺(1.83米),72英寸 - 运输尺寸:9.00x7.00x0.50英寸 - 运输重量:0.54磅(0.24公斤) - 标准与合规:符合RoHS标准 - 保修与支持:提供终身有限保修
功能详解: - 支持连接DVI-I视频端口到VGA显示器或VGA视频端口到DVI-I显示器 - 采用迷你同轴(RGB)和配对视频线构造,提供优越的信号质量 - 镀金铜触点确保优秀的导电性 - 符合DVI DDWG标准,仅支持模拟信号
应用信息: 兼容平板显示器、数字CRT显示器和投影仪,适用于需要从DVI-I到VGA或从VGA到DVI-I连接的场景。
封装信息: - 颜色:黑色 - 线缆外皮材料:PVC - 线缆外皮等级:VW-1 - 线缆长度:6英尺(1.8米),72英寸 - 发货尺寸:9.00x7.00x0.50英寸 - 发货重量:0.54磅(0.24公斤)
P556-006 价格&库存
很抱歉,暂时无法提供与“P556-006”相匹配的价格&库存,您可以联系我们找货
P556-006
  • 1+118.711291+15.37727
  • 10+100.9029910+13.07047
  • 25+94.5799725+12.25142
  • 50+90.0661550+11.66672
  • 100+85.76840100+11.11001
  • 250+80.40241250+10.41493
  • 500+76.56896500+9.91836
  • 1000+75.737111000+9.81061
库存:72
