M100-006-WH
M100-006-WH
    TRIPPLITE
    M100-006-WH
M100-006-WH 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-A to Lightning Sync/Charge Cable (M/M) MFi Certified, White, 6 ft. (1.8 m) MODEL NUMBER: M100-006-WH Highlights ● Reversible Lighting plug compatible with all devices with 8-pin connectors ● USB plug connects to USB-A port on computer or charger ● MFi-certified for use with iPhone, iPad and iPod devices System Requirements ● Device or charger with USB-A port ● Most current iPhone, iPad and iPod devices Package Includes M100-006-WH USB-A to Lightning Sync/Charge Cable (M/M), White, 6 ft. (1.8 m) Charges and synchronizes your Apple iPhone, iPad or iPod using the USB port on your computer or wall/car charger. Features Helps You Charge and Sync Your Apple Mobile Device The M100-006-WH connects your iPhone, iPad or iPod to the USB-A port on a computer or USB charger, so you can charge your Apple device and transfer data simultaneously. The reversible 8-pin Lightning plug connects in either direction to ensure fast, easy connection every time. The charging cable is MFicertified for broad compatibility with iPhone, iPad and iPod devices. Specifications OVERVIEW UPC Code 037332182180 Technology Lightning; USB; USB 2.0 (High Speed) Cable Type Passive INPUT Maximum Input Amps 2 POWER USB Power Delivery (PD) Charging Support No CHARGING Total Charging Watts 12 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction PVC Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.2mm Wire Gauge (AWG) 28/21 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 4.57 x 2.36 x 0.05 Shipping Dimensions (hwd / cm) 11.61 x 5.99 x 0.13 Shipping Weight (lbs.) 0.05 Shipping Weight (kg) 0.02 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 176°F (-20° to 80°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 12W (5V/2.4A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Data Transfer Rate 480 Mbps Angled Plug No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications MFi Product Compliance RoHS; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M100-006-WH 价格&库存
很抱歉,暂时无法提供与“M100-006-WH”相匹配的价格&库存,您可以联系我们找货
