M100-006-BK
M100-006-BK
    TRIPPLITE
    CABLE
M100-006-BK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-A to Lightning Sync/Charge Cable, MFi Certified - Black, M/M, USB 2.0, 6 ft. (1.83 m) MODEL NUMBER: M100-006-BK Highlights ● Features a reversible 8-pin Lightning plug and a USB-A plug ● Works with any computer ● MFi-certified for broad compatibility with your Apple iPhone, iPad or iPod ● Compatible with all devices with 8-pin connectors ● Plugs into Apple device in either direction Applications ● Charge and sync your Apple iPhone, iPad or iPod using the USB-A port on your computer or a wall charger up to 6-ft. (1.83 m) away ● Transfer photos and other important files between an external hard drive and your Apple device This USB Type-A to Lightning cable connects your iPhone, iPad or iPod device to the USB port on your computer or wall/car charger System Requirements Features Tripp Lite's M100-006-BK 6-ft. (1.83 m) Black USB Sync / Charge Cable with Lightning connector allows for uploading and downloading data, while charging the devices at the same time. Cable is MFi-certified for use with the latest generation of iPhone, iPad and iPod devices. Reversible Lightning connector allows plug-ability in either direction to the device. ● Device or charger with USB-A port ● Most current iPhone, iPad and iPod devices Package Includes ● Specifications OVERVIEW UPC Code 037332182166 Technology Lightning; USB; USB 2.0 (High Speed) Cable Type Passive INPUT Maximum Input Amps 2 POWER USB Power Delivery (PD) Charging Support No 1/3 M100-006-BK USB Sync/Charge Cable with Apple Lightning Connector 1000 Eaton Boulevard Cleveland, OH 44122 United States CHARGING Total Charging Watts 12 PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.2mm Wire Gauge (AWG) 28/21 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 5.30 x 1.00 x 2.60 Shipping Dimensions (hwd / cm) 13.46 x 2.54 x 6.60 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 176°F (-20° to 80°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 12W (5V/2.4A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Data Transfer Rate 480 Mbps Angled Plug No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications MFi Product Compliance RoHS; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M100-006-BK
物料型号: - 型号编号:M100-006-BK
器件简介: - 这是一款USB-A至Lightning同步/充电线,MFi认证,黑色,长度为6英尺(1.8米)。它支持与所有具有8针连接器的设备的连接,并且可以与iPhone、iPad和iPod设备配合使用。
引脚分配: - 连接器1(Side A):USB A(公头) - 连接器1(Side B):LIGHTNING(公头)
参数特性: - 技术:Lightning;USB 2.0(高速) - 电缆类型:被动 - 最大输入安培数:2 - USB电源传输(PD)充电支持:否 - 连接器电镀:镍 - 接触电镀:金 - 连接器样式:直式 - 总充电瓦数:12 - 材料构造:PVC - 电缆外径(OD):3.2mm - 线规(AWG):28/21 - 电缆长度:6英尺(1.83米) - 发货尺寸:5.30x1.00x2.60英寸 - 发货重量:0.10磅(0.05公斤) - 操作温度范围:-4°F至140°F(-20°C至60°C) - 存储温度范围:-4°F至176°F(-20°C至80°C) - 操作湿度范围:0%至90% RH,非凝结 - 存储湿度范围:0%至90% RH,非凝结 - 连接设备供电:12W(5V/2.4A) - 数据传输率:480 Mbps
功能详解: - 该线缆可以将iPhone、iPad或iPod连接到电脑或USB充电器的USB-A端口,允许同时为苹果设备充电和传输数据。可逆8针Lightning插头可以双向连接,确保每次连接快速且容易。充电线缆经过MFi认证,与iPhone、iPad和iPod设备广泛兼容。
应用信息: - 适用于大多数当前的iPhone、iPad和iPod设备,以及带有USB-A端口的设备或充电器。
封装信息: - 电缆颜色:黑色 - 电缆材料:PVC - 电缆外径:3.2mm - 线规:28/21 - 电缆长度:6英尺(1.83米)
M100-006-BK 价格&库存
很抱歉,暂时无法提供与“M100-006-BK”相匹配的价格&库存,您可以联系我们找货
