2200-003003
2200-003003
    STORMINTERFACE
2200-003003 数据手册
2200 Series Panel-mount Trackballs Rugged cursor control for industrial and hostile public environments • 38mm panel-mount trackball provides smooth, responsive and precise cursor control • Vandal resistant version features a stainless steel retention ring and a coated steel ball (mirror finish) (10J BS EN 60068-2-75: 1997) • Robust version features a tough phenolic resin ball (black) • Robust chassis designed to provide secure under-panel fixing for maximum resistance to hard use, abuse and vandalism • On-board encoder automatically configures to provide either USB or PS2 connectivity • Two ‘click keys’ (not supplied) can be connected directly to the on-board encoder • Sealed against the ingress of liquids • USB and PS2 cables for & dust to IP65 when ball is connection to host system are stationary (IP54 when rotating) available separately • Operating temp: -20 oC (dry) to +60 oC www.storm-interface.com Storm Interface products include technology protected by international patents and design registration. All rights reserved. Panel-mount trackballs for industrial and public environments These 38mm trackballs provide smooth, accurate and responsive cursor control in wet, dirty or aggressive environments. Each device automatically configures to provide USB or PS2 connectivity. Two selector (click) buttons (not supplied) can be configured to provide either left and right click functions or for both buttons to provide left click functions only. These trackballs can be installed as a flush mounted component in a control panel or equipment housing. Cables enabling connection to either USB or PS2 systems are supplied separately. The trackballs are constructed to ensure maximum resistance to hard use, abuse, and vandalism. 52.5 Overall Dimensions Panel Preparation Details (Vandal plate not shown) 60 43 CONNECTOR P1 1 2 3 4 5 6 52.5 Trackball o 38.0mm CONNECTOR P3 1 2 3 4 5 6 P2 Panel Thickness: 1.5 – 3.0mm M3 x 40mm studs (4off) 25 Connector Pinout Details Pin Button Connections (P1) PS2 / USB Output Connections (P3) 1 0V D- / Data 2 Button 1 (left) D+ / Clock 3 0V Test Only 4 Button 2 (right) Power +5V 5 0V Ground 0V 6 Button 3 (middle) Not used The unit automatically selects either USB or PS/2 protocols on power-up. No re-setting of any DIP switches required. If both buttons are required to be set as left click then a connection must be made between pins on connector P2 using the jumper device (supplied). Please note that the TEST input is reserved for factory test only. On no account should a connection be made to this terminal. The Button inputs are pulled high to 5V within the unit. Both rising and falling edges of this signal are debounced for 30ms. The Storm Trackball is designed to work with resident drivers and does not require additional software to be loaded. Electrical Environmental Supply Voltage 5.0V dc ±10% Switch Debounce 30ms rising/falling Supply Current 15mA maximum Resolution 150 pulses, 600 counts/revolution Operating Temp -20oC (dry) to +60oC IP65 seal when ball stationary IP54 seal when ball rotating Humidity 95% Rh max, non-condensing Mechanical Material Tracking Force Ball Speed Operational Life Mounting Angle 50g nominal any direction 250 rpm maximum 10 million revolutions (min) within 45o from horizontal Robust Trackball Vandal Resistant Trackball Seal Material Vandal Plate Phenolic Resin Surface Treated Steel PTFE with low friction fill Stainless Steel NB. Robust Version does not have Vandal Plate Installation Prepare plate with hole for o43.0mm bezel and M3 x 40mm studs on 52.5mm centres. Fit sealing gasket to trackball. Place trackball over studs. Place vandal plate over studs (VR version only). Secure with plain washers and Nyloc nuts. IMPORTANT: Max torque 40Ncm on nuts. Connect switches to connector P1. If reqd,fit jumper to enable both buttons as left click. Accessories [x] denotes packaging variant Stock No. 2200-00200[x] 2200-00300[x] 2200-00020[x] 2200-00030[x] Item Cable 2.5m PS2 Cable 2.5m USB Trackball Unit PS2 / USB Black Phenolic Ball Trackball Unit PS2 / USB Coated Steel Ball Whilst every effort is made to ensure details are correct at time of print, specifications are subject to change without notice. Storm is a trademark of Keymat Technology Ltd Storm Interface is a trading name of Keymat Technology Ltd UL File reference: E230121 Designed & produced by NIK Design www.nikdesign.co.uk 003 2200-LIT-01 Rev 4 Nov 2008 FM 39602 Storm Interface products include technology protected by international patents and design registration. All rights reserved.
2200-003003 价格&库存
很抱歉,暂时无法提供与“2200-003003”相匹配的价格&库存,您可以联系我们找货
