P946-12N-2P15
P946-12N-2P15
    TRIPPLITE
    CABLEPOWER
P946-12N-2P15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Molex 4-Pin to 2x 15-Pin SATA Power Cable M/2xF, 26 AWG, 1 ft. (0.31 m) MODEL NUMBER: P946-12N-2P15 Highlights ● Connects any 2 Serial SATA drives to one standard internal 4-pin Molex power supply ● Compatible with 2.5 in. and 3.5 in. SATA drives Applications ● Use power from your computer via its LP4 connection to operate your SATA drives with a desktop computer or server containing multiple drives Package Includes ● Supplies power to dual SATA hard drives from a single power supply connection. Features Dual 15-Pin SATA to 4-Pin Molex Power Cable Needs Only an LP4 Power Supply ConnectionThis Molex 4-pin to 2x 15-pin SATA power cable connects any two Serial ATA drives to any conventional LP4 internal connector. Ideal for desktops or servers equipped with 2.5 in. or 3.5 in. SATA hard drives, this one-foot cable features one 4-pin Molex (LP4) female connector and two 15-pin SATA power connectors. It eliminates the need to upgrade the computer power supply for compatibility with newer SATA drives. Specifications OVERVIEW UPC Code 037332185334 Technology SATA/eSATA Country/Region Global INPUT Maximum Input Amps 0 PHYSICAL Color Black; Red; Yellow Number of Conductors 0 Wire Gauge (OD - mm²) 0 Cable Length (ft.) 1 Cable Length (m) 0.30 1/2 P946-12N-2P15 Molex 4-Pin to 2x 15-Pin SATA Power Cable, M/2xF, 1 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (in.) 12 Cable Length (cm) 30.48 Shipping Dimensions (hwd / in.) 5.30 x 3.90 x 0.50 Shipping Dimensions (hwd / cm) 13.46 x 9.91 x 1.27 Shipping Weight (lbs.) 0.14 Shipping Weight (kg) 0.06 CONNECTIONS Side A - Connector 1 (2) 15 PIN SATA POWER (FEMALE) Side B - Connector 1 LP4 (MALE) FEATURES & SPECIFICATIONS High Voltage No Locking Plug No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P946-12N-2P15 价格&库存
很抱歉,暂时无法提供与“P946-12N-2P15”相匹配的价格&库存,您可以联系我们找货
