P947-06N-2P15
P947-06N-2P15
    TRIPPLITE
    P947-06N-2P15
P947-06N-2P15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 15-Pin SATA Power Y Cable - M/2xF, 18 AWG, 6in. (15.24 cm) MODEL NUMBER: P947-06N-2P15 Highlights ● Allows any 2 SATA hard drives to share a single power connection ● Compatible with 2.5 in. and 3.5 in. SATA drives ● Plug-and-play operation makes it easy to connect in seconds Applications ● Connect 2 SATA drives to a single SATA power supply without having to upgrade the computer power supply Package Includes ● Adds a SATA hard drive to a computer or server when no additional power supply wiring harness connectors are available. Features 15-Pin Splitter Allows Additional SATA Drive to be Added to a Computer or ServerThis 15-pin SATA power Y cable allows an additional SATA hard drive to be added to a computer or server when no additional power supply wiring harness connectors are available. Simply unplug a SATA hard drive power cable from the existing SATA hard drive and connect the plug-and-play splitter to the power cable's 15-pin female end. Reconnect the old and new drives with the two new female 15-pin ends. This eliminates the need to upgrade the computer power supply for compatibility with an additional SATA drive. Specifications OVERVIEW UPC Code 037332185327 Technology SATA/eSATA Country/Region Global INPUT Maximum Input Amps 1.5 PHYSICAL Color Black; Red; Yellow Number of Conductors 0 Wire Gauge (OD - mm²) 2.0 Cable Length (ft.) 0.5 1/2 P947-06N-2P15 15-Pin SATA Power Y Cable - M/2xF, 6 in. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 0.15 Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 0.50 x 4.00 x 5.50 Shipping Dimensions (hwd / cm) 1.27 x 10.16 x 13.97 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 CONNECTIONS Side A - Connector 1 15 PIN SATA POWER (MALE) Side B - Connector 1 (2) 15 PIN SATA POWER (FEMALE) FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No High Voltage No Locking Plug No STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P947-06N-2P15
物料型号: - 型号编号:P947-06N-2P15
器件简介: - 15针SATA电源Y型线,用于连接2个SATA硬盘共享一个电源接口,支持2.5英寸和3.5英寸SATA硬盘,即插即用,操作简便。
引脚分配: - Side A - 连接器1:15针SATA电源(公头) - Side B - 连接器1:2个15针SATA电源(母头)
参数特性: - UPC代码:037332185327 - 技术:SATA/eSATA - 适用地区:全球 - 输入:最大输入安培1.5 - 颜色:黑色、红色、黄色 - 导体数量:0 - 线规(外径mm²):2.0 - 电缆长度:0.5英尺/0.15米/6英寸/15.24厘米 - 发货尺寸:0.50x4.00x5.50英寸/1.27x10.16x13.97厘米 - 发货重量:0.06磅/0.03千克 - 产品合规:RoHS; REACH - 产品保修期:全球有限终身保修
功能详解: - 允许在没有额外电源供应接线束连接器的情况下,将额外的SATA硬盘添加到计算机或服务器。通过将即插即用的Y型线连接到现有SATA硬盘的15针母头端,并使用两个新的15针母头端重新连接旧硬盘和新硬盘,从而无需升级计算机电源供应即可兼容额外的SATA硬盘。
应用信息: - 无需升级计算机电源即可连接2个SATA硬盘到单个SATA电源。 - 在没有额外的电源供应接线束连接器可用时,向计算机或服务器添加SATA硬盘。
封装信息: - 封装颜色:黑色、红色、黄色 - 电缆长度:6英寸/15.24厘米
P947-06N-2P15 价格&库存
很抱歉,暂时无法提供与“P947-06N-2P15”相匹配的价格&库存,您可以联系我们找货
P947-06N-2P15
  • 1+32.310811+4.19336
  • 10+27.4166910+3.55819
  • 25+25.6936625+3.33457
  • 50+24.4650650+3.17512
  • 100+23.29719100+3.02355
  • 250+21.83848250+2.83424
  • 500+20.79618500+2.69897
  • 1000+19.804101000+2.57021
  • 2500+18.565412500+2.40945
库存:17
