P138-000-DVI
P138-000-DVI
    TRIPPLITE
    P138-000-DVI
P138-000-DVI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DVI to DVI Cable Adapter, Video Converter for Macbooks and iMacs, 1920x1200 (Mini DVI to DVI-D M/F) Highlights ● Connect a DVI Monitor to Apple Intel iMac, MacBook, and 12in PowerBook G4 mini-DVI Port ● 8 in. overall length MODEL NUMBER: P138-000-DVI System Requirements ● Apple Intel iMac, MacBook, and 12in PowerBook G4 Package Includes ● Description Tripp Lite's mini-DVI to DVI-D Digital Female Video Adapter Cable allows you to connect a DVI-D Display to the mini-DVI port found on some Apple computer models. Supports Single Link digital transmission, with resolutions up to 1920x1200@60Hz. Features ● Connect a DVI Monitor to Apple Intel iMac, MacBook, and 12-in. PowerBook G4 mini-DVI Port ● 8 in. overall length ● 1920x1200 @ 60Hz resolution Specifications OVERVIEW UPC Code 037332152138 Product Type Video Adapter Device Compatibility Computer; Laptop; Tablet Technology DVI PHYSICAL Color White Cable Jacket Color White Cable Length (ft.) 0.7 1/2 8-in. mini-DVI to DVI-D Adapter 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (m) 0.21 Cable Length (in.) 8 Cable Length (cm) 20.32 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.31 Shipping Weight (kg) 0.14 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Unit Weight (lbs.) 0.14 Unit Weight (kg) 0.06 CONNECTIONS Side A - Connector 1 MINI-DVI (MALE) Side B - Connector 1 DVI-D DUAL LINK (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P138-000-DVI
物料型号:P138-000-DVI
器件简介:这款Mini DVI到DVI-D数字视频适配器电缆,允许您将DVI-D显示器连接到一些苹果电脑型号上的Mini DVI端口。
支持单链路数字传输,分辨率可达1920×1200,刷新率为60Hz。
引脚分配:Side A - 1个Mini DVI(公头),Side B - 1个DVI-D双链路(母头)
参数特性: - 支持的分辨率:1920x1200 @ 60Hz - 传输技术:DVI - 线缆长度:8英寸(约20.32厘米) - 颜色:白色
功能详解:该适配器电缆支持将DVI显示器连接到苹果的Intel iMac、MacBook和12英寸PowerBook G4的Mini DVI端口,提供高分辨率视频传输。
应用信息:适用于苹果的Intel iMac、MacBook和12英寸PowerBook G4电脑,用于连接DVI显示器。
封装信息:线缆长度为8英寸(约20.32厘米),线缆颜色为白色,包装尺寸为9.00x7.00x0.50英寸(约22.86x17.78x1.27厘米),运输重量约为0.31磅(约0.14千克)。
此外,该产品符合RoHS标准,并提供有限的终身保修。
P138-000-DVI 价格&库存
很抱歉,暂时无法提供与“P138-000-DVI”相匹配的价格&库存,您可以联系我们找货
P138-000-DVI
  • 1+56.101701+7.27185
库存:8
