P566-003
P566-003
    TRIPPLITE
    P566-003
P566-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI to DVI Cable, Digital Monitor Adapter and Video Converter (HDMI to DVI-D M/M), 3 ft. (0.91 m) Highlights ● Premium double shielded digital video cable protects against EMI/RFI noise. ● Gold plated connectors and contacts provide optimal signal transfer. ● Supports high-def video resolutions up to 1920 x 1080 @60Hz (1080p). ● Supports a bandwidth up to 5Gbps ● This product is covered by a Lifetime Limited Warranty MODEL NUMBER: P566-003 Package Includes ● Creates a pure bi-directional digital connection between a DVI-enabled computer and an HDMI-enabled display or an HDMI-enabled computer and a DVI-enabled display. Description Tripp Lite's 3-ft. (0.91 m) HDMI - DVI ( High Definition Multimedia Interface ) cable allows interconnection between digital display devices, such as DTV's ( Digital Television ), Plasma displays, LCD TV's, and projectors, to Digital source devices, such as Digital Set-Top boxes, DVD/DVD-R players, and AV receivers. HDMI DTV's will display video received from existing DVI-equipped products, and DVI-equipped TVs will display video from HDMI sources. HDMI technology uses a much more compact and user-friendly connector than the existing DVI connector. The HDMI specification handles higher-bandwidth, uncompressed video, and multi-channel digital audio, all in one neat cable solution. (HDMI-DVI cable supports digital video only and does not support audio). Features ● 3-ft. (0.91 m) HDMI to DVI Adapter Cable ● Creates a pure bi-directional digital connection between a DVI-enabled computer and an HDMI-enabled display or an HDMI-enabled source and a DVI-enabled display. ● Gold plated connectors provide optimal signal transfer ● Premium Double-Shielded compliant cable protects against outside noise (EMI/RFI) ● Impedance matched twisted pair construction reduces cross-talk and interference ● Supports High-Definition (HD) video resolutions up to 1920 x 1080 @60Hz (1080p). Specifications OVERVIEW UPC Code 037332181312 Product Type Passive Cable 1/3 3-ft. (0.91 m) HDMI to DVI Gold Digital Video Cable (HDMI-M / DVI-M) 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology DVI; HDMI Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 Unit Packaging Type Polybag ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Connector Plating Gold Contact Plating Gold Latching or Gripping Connector No FEATURES & SPECIFICATIONS Antibacterial No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States IP68 Rated No Armored Cable No HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P566-003
1. 物料型号: - 型号编号:P566-003 - 产品类型:被动线缆(Passive Cable) - 技术:DVI、HDMI
2. 器件简介: - 该产品为HDMI至DVI的线缆,用于连接DVI兼容的电脑和HDMI兼容的显示器,或HDMI兼容的电脑和DVI兼容的显示器。 - 支持高清视频分辨率高达1920 x 1080 @60Hz(1080p)。 - 支持高达5Gbps的带宽。
3. 引脚分配: - 侧A - 连接器1:HDMI(公头) - 侧B - 连接器1:DVI-D单链路(公头)
4. 参数特性: - 最大支持视频分辨率:1920x1200(1080p) - 连接器镀金:是 - 接触点镀金:是 - 锁扣或抓握连接器:无 - 物理特性:黑色PVC材质,外径5.5mm,线规30AWG,线长3英尺(0.91米)。
5. 功能详解: - 该线缆创建了一个纯双向数字连接,允许数字显示设备(包括高清电视和投影仪)与数字源设备(如卫星/有线电视盒、蓝光播放器和AV接收器)之间的互连。 - HDMI技术使用比现有DVI连接器更紧凑、用户友好的连接器。HDMI规范处理更高的带宽、未压缩的视频和多通道数字音频,全部集成在一个整洁的电缆解决方案中。(HDMI-DVI线缆仅支持数字视频)。
6. 应用信息: - 该线缆适用于连接HDMI和DVI设备,如高清电视、投影仪、卫星/有线电视盒、蓝光播放器和AV接收器。
7. 封装信息: - 单位包装类型:聚乙烯袋 - 操作温度范围:32°F至113°F(0°C至45°C) - 存储温度范围:14°F至158°F(-10°C至70°C) - 操作湿度范围:10%至85% RH,非凝结 - 存储湿度范围:5%至90% RH,非凝结
P566-003 价格&库存
很抱歉,暂时无法提供与“P566-003”相匹配的价格&库存,您可以联系我们找货
P566-003
    • 1+109.946591+14.19194
