P139-06N-DP
P139-06N-DP
    TRIPPLITE
    P139-06N-DP
P139-06N-DP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Keyspan Mini DisplayPort to DisplayPort Cable Adapter, Video Converter (M/F), 6-in. (15.24 cm) MODEL NUMBER: P139-06N-DP Highlights ● Converts Mini Displayport on a MAC to Displayport Female ● Connect Displayport enabled monitor to a MAC computer ● Supports resolutions up to 2560 x 1600 @ 60Hz Package Includes 6-inch Mini Displayport Male to Displayport Female Adapter Features ● Connect a Displayport enabled Monitor to a MAC Mini-Displayport video port ● Plug and Play - no drivers or setup needed ● Displayport 1.1a Compliant ● HDCP Compliant ● Supports resolutions up to 2560 x 1600 @ 60Hz Specifications OVERVIEW UPC Code 037332161277 Product Type Video Adapter Technology DisplayPort PHYSICAL Color White Cable Jacket Color White Cable Length (ft.) 0.5 Cable Length (m) 0.15 Shipping Dimensions (hwd / in.) 0.25 x 0.25 x 6.50 Shipping Dimensions (hwd / cm) 0.64 x 0.64 x 16.51 Shipping Weight (lbs.) 0.05 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.02 CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P139-06N-DP
1. 物料型号: - 型号编号:P139-06N-DP
2. 器件简介: - 该产品为Keyspan Mini DisplayPort到DisplayPort的转接器,可以将MAC上的Mini DisplayPort转换为DisplayPort Female,以便连接支持DisplayPort的显示器。
3. 引脚分配: - Side A - Connector 1:MINI DISPLAYPORT (MALE) - Side B - Connector 1:DISPLAYPORT (FEMALE)
4. 参数特性: - 支持即插即用,无需驱动或设置。 - 符合DisplayPort 1.1a标准。 - 支持HDCP。 - 支持最高分辨率2560 x 1600 @ 60Hz。
5. 功能详解: - 连接支持DisplayPort的显示器到MAC Mini-Displayport视频端口。 - 无需额外驱动或设置,即插即用。 - 支持高分辨率显示,最高可达2560 x 1600 @ 60Hz。
6. 应用信息: - 适用于需要将MAC电脑连接到DisplayPort显示器的场景。
7. 封装信息: - 颜色:白色。 - 线缆长度:0.5英尺(0.15米)。 - 线缆外皮颜色:白色。
P139-06N-DP 价格&库存
很抱歉,暂时无法提供与“P139-06N-DP”相匹配的价格&库存,您可以联系我们找货
