P564-06N-DV
P564-06N-DV
    TRIPPLITE
    P564-06N-DV
P564-06N-DV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI Y Splitter Cable, Digital and VGA Monitors (DVI-I M to DVI-D F and HD15 F) 6-in. (15.24 cm) MODEL NUMBER: P564-06N-DV Highlights ● Splits a DVI-I signal into DVI-D and VGA ● DVI-I Male splits to DVI-D Female and HD15 Female ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p (60Hz) ● Comparable to Wyse 92030202L and Dell 0X2026 System Requirements ● A computer with a DVI-I Digital/Analog port ● Simultaneous display of both DVI-D and VGA monitors is not possible with all video cards. Check your computer's video card documentation for compatibility with DVI to DVI + VGA Y splitter cables. Package Includes Features ● ● Splits a DVI-I signal into DVI-D and VGA ● DVI-I Male splits to DVI-D Female and HD15 Female ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p (60Hz) ● Comparable to Wyse 920302-02L and Dell 0X2026 Specifications OVERVIEW UPC Code 037332181534 Product Type Splitter Technology DVI; VGA/SVGA Host Connector DVI-I DUAL LINK (MALE) Cable Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 0.5 Cable Length (m) 0.15 Cable Length (in.) 6 1/2 6-in. DVI Y Splitter Cable (DVI-I M to DVI-D F and HD15 F) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 CONNECTIONS Side A - Connector 1 DVI-I DUAL LINK (MALE) Side B - Connector 1 DVI-D DUAL LINK (FEMALE) Side B - Connector 2 HD15 (FEMALE) Latching or Gripping Connector No Input x Output 1x2 Daisy-chainable / Cascadable No FEATURES & SPECIFICATIONS MST Support No IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P564-06N-DV
物料型号: - 型号编号:P564-06N-DV
器件简介: - Tripp Lite系列DVI Y Splitter Cable可将DVI-I信号分割成DVI-D和VGA信号,适用于数字和VGA显示器。
引脚分配: - 主连接器(Side A):DVI-I双链路(公头) - 侧B连接器1:DVI-D双链路(母头) - 侧B连接器2:HD15(母头)
参数特性: - 支持的电脑视频分辨率最高可达1920×1200,高清分辨率最高可达1080p(60Hz)。 - 不支持通过DVI到DVI+VGA Y型线同时显示DVI-D和VGA监视器。需要检查电脑显卡文档以确认兼容性。
功能详解: - 分割DVI-I信号为DVI-D和VGA。 - 产品不支持串联/级联。
应用信息: - 需要有DVI-I数字/模拟端口的电脑。 - 适用于需要将单一DVI-I信号源分配到两个不同显示器的场景。
封装信息: - 颜色:黑色 - 电缆长度:0.5英尺(15.24厘米) - 运输尺寸:9.00x7.00x0.50英寸 - 运输重量:约0.24磅(0.11千克)
其他信息: - UPC代码:037332181534 - 产品类型:Splitter(分割器) - 技术:DVI;VGASVGA - 被动式电缆 - 输入x输出:1x2 - 产品合规性:RoHS - 产品保修期(全球):有限终身保修
P564-06N-DV 价格&库存
很抱歉,暂时无法提供与“P564-06N-DV”相匹配的价格&库存,您可以联系我们找货
