P586-006-HDMI
P586-006-HDMI
    TRIPPLITE
    MINI TO HDMI ADAPT 6'
P586-006-HDMI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort to HDMI Active Adapter Cable (M/M), 1080p, 6 ft. (1.8 m) MODEL NUMBER: P586-006-HDMI Highlights ● Supports 1080P 1920x1080 resolution ● Supports Audio ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode port System Requirements ● Not for use with MST Hubs. For compatibility with MST Hubs, use a Displayport 1.2 compliant product such as P586-006-HDV2A Package Includes ● Connect a Computer with Mini Displayport or Thunderbolt to a HDMI enabled TV Features ● 6ft Mini Displayport / Thunderbolt to HDMI Adapter cable ● Supports 1080P video, as well as audio ( if video card enabled ) ● HDCP compatible ● In-line Passive adapter ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dual-mode port Specifications OVERVIEW UPC Code 037332180704 Product Type Active Cable Technology HDMI; DisplayPort VIDEO Max Supported Video Resolution 1920 x 1080 (1080p) Max Supported Color Depth 12-bit True Color HDR Support No Chroma Sub Sampling 4:4:4 PHYSICAL 1/3 6-ft. (1.83 m) Mini Displayport / Thunderbolt to HDMI Adapter cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Material of Construction ABS, PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8mm Wire Gauge (AWG) 32 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 0.25 x 5.00 x 8.30 Shipping Dimensions (hwd / cm) 0.64 x 12.70 x 21.08 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) Operating Humidity Range 10% to 85%, Non-Condensing Storage Humidity Range 5% to 90%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold; Nickel Contact Plating Gold FEATURES & SPECIFICATIONS Displayport Specification 1.1a HDCP Specification 1.3 IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (U.S. & Canada) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P586-006-HDMI 价格&库存
很抱歉,暂时无法提供与“P586-006-HDMI”相匹配的价格&库存,您可以联系我们找货
P586-006-HDMI
    • 1+268.400091+34.53912
