P586-006-DVI
P586-006-DVI
    TRIPPLITE
    P586-006-DVI
P586-006-DVI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort 1.2 to DVI Adapter Cable (M/M), 1080p, 6 ft. (1.8 m) MODEL NUMBER: P586-006-DVI Highlights ● All in one Mini Displayport to DVI cable design ● Supports 1080P 1920x1080 resolution ● Low-profile DVI connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode port ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements Connect a Computer with Mini Displayport to a DVI enabled Monitor ● Computer with Mini Displayport video port ● DVI Monitor ● Not for use with MST Hubs. For compatibility with MST Hubs, use a Displayport 1.2 compliant product such as P586-006-DVIV2 Description Tripp Lite's P586-006-DVI, 6-ft. (1.83 m) Mini-Displayport to DVI cable, allows you to connect a computer with Mini-Displayport video out port, to a DVI enabled Monitor. It features a low profile DVI connector that fits neatly into the available monitor space, without jamming between the wall and the back of the display or impeding neighboring connectors. Male to Male design eliminates the need for separate adapter and cable. In-line passive adapter is designed for use with Dual Mode ( DP++) Displayport graphics cards. Supports 1920 x 1200 resolution, as well as HDTV 1080P. The P586-006-DVI is compliant with the Federal Trade Agreements Act (TAA), which makes it eligible for GSA (General Services Administration) Schedule and other federal procurement contracts. Features ● 6-ft. (1.83 m) Mini Displayport to DVI Adapter cable ● Supports 1080P video, as well as audio ( if video card enabled ) ● Low-profile DVI connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● In-line Passive adapter ● Plug-and-Play ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dual-mode port Specifications OVERVIEW UPC Code 037332180766 Product Type Passive Cable Technology DVI; DisplayPort 1/3 Package Includes ● 6-ft. (1.83 m) Mini Displayport to DVI Adapter Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Type Passive VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 24-bit True Color HDR Support No PHYSICAL Color Black Material of Construction ABS, PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0 +/- 15mm Wire Gauge (AWG) 32 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.25 Shipping Weight (kg) 0.11 Unit Dimensions (hwd / in.) 9.000 x 7.000 x 0.500 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0% to 85%, Non-Condensing Operating Humidity Range 0% to 85%, Non-Condensing Storage Humidity Range 0% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Connector Plating Nickel Contact Plating Gold Latching or Gripping Connector No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No Displayport Specification 1.2 STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; Trade Agreements Act (TAA); UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty Product Warranty Period (U.S. & Canada) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P586-006-DVI 价格&库存
很抱歉,暂时无法提供与“P586-006-DVI”相匹配的价格&库存,您可以联系我们找货
