U209-005-C
U209-005-C
    TRIPPLITE
    U209-005-C
U209-005-C 数据手册
USB-C to RS232 (DB9) Serial Adapter Cable (M/M), 5 ft. (1.52 m) MODEL NUMBER: U209-005-C Highlights ● Supports data transfer speeds up to 230 Kbps ● Premium foil and braid shielding reduces EMI/RFI interference ● Compatible with Windows®, Mac®, Linux® and Android™ devices ● No external power source required ● Portable 5 ft. design fits perfectly into laptop bag System Requirements ● Windows 2000 and later (including Windows 11) ● Mac OS X 10.6 through 10.12 ● Linux Redhat 7.3 through 9.0 (Linux Kernel 2.4.31 and above include built-in drivers) ● Android devices with USB Host Mode (OTG) support and OS 3.2 and later. USB Host Mode (OTG) cable required. Connect a device with a 9-pin RS-232 serial port to the USB Type-C port on your computer, laptop, tablet or smartphone. Perfect for connecting modems, digital cameras, PDAs and ISDN terminals. Features Package Includes Connects a DB9 Device to a USB-C Device ● Ideal for connecting a modem, digital camera, PDA or ISDN terminal to your computer, laptop, tablet or smartphone ● Supports data transfer speeds up to 230 Kbps—twice as fast as a built-in serial port ● No external power source required ● Portable 5 ft. design fits perfectly into laptop bag First-Rate Construction for Superior Signal Transfer ● Premium foil and braid shielding for EMI/RFI noise protection ● Molded nickel-plated connectors with gold-plated contacts for optimal signal quality ● Integral strain relief for long life ● Twisted 28/24 AWG data/power lines ● Flexible PVC jacket easy to install in tight spaces Broad Compatibility ● Compatible with Windows, Mac, Linux and Android devices (see System Requirements for details) Specifications OVERVIEW UPC Code 037332197573 Technology Serial; USB 1/2 ● U209-005-C USB-C to DB9 Serial Adapter Cable (M/M), 5 ft. ● Owner’s manual Host Connector USB C (MALE) PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 5 Cable Length (m) 1.52 Shipping Dimensions (hwd / in.) 1.22 x 4.40 x 4.60 Shipping Dimensions (hwd / cm) 3.10 x 11.18 x 11.68 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 CONNECTIONS Side A - Connector 1 USB C (MALE) Side B - Connector 1 DB9 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U209-005-C
物料型号: - 型号编号:U209-005-C
器件简介: - 该产品为USB-C至RS232(DB9)串行适配器线(公/母),长度为5英尺(1.52米)。支持数据传输速度高达230 Kbps,无需外部电源,便携式5英尺设计非常适合放入笔记本电脑包中。
引脚分配: - 侧A - 连接器1:USB C(公) - 侧B - 连接器1:DB9(公)
参数特性: - 支持的数据传输速度高达230 Kbps,是内置串行端口的两倍速度。 - 高级箔和编织屏蔽减少EMI/RFI干扰。 - 无需外部电源。 - 5英尺长的便携式设计非常适合放入笔记本电脑包中。
功能详解: - 连接一个DB9设备到USB-C设备,非常适合连接调制解调器、数码相机、PDA或ISDN终端到电脑、笔记本电脑、平板电脑或智能手机。
应用信息: - 适用于连接调制解调器、数码相机、PDA和ISDN终端。 - 适用于Windows、Mac、Linux和Android设备(详见系统要求)。
封装信息: - 电缆长度:5英尺(1.52米)。 - 电缆颜色:未提供具体信息。 - 发货尺寸:1.22x4.40x4.60英寸;3.10x11.18x11.68厘米。 - 发货重量:未提供具体数值。
U209-005-C 价格&库存
很抱歉,暂时无法提供与“U209-005-C”相匹配的价格&库存,您可以联系我们找货
U209-005-C
  • 1+308.571511+39.99675
