P586-006-VGA
P586-006-VGA
    TRIPPLITE
    MONITOR TO VGA ADAPT CBL M/M 6'
P586-006-VGA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort to VGA Active Adapter Cable (M/M), 6 ft. (1.8 m) MODEL NUMBER: P586-006-VGA Highlights ● Connect a Mini Displayport computer port to a VGA monitor ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● Ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals ● Converts both Single-Mode and Dual Mode (DP++) Displayport output System Requirements ● VGA Monitor ● Computer with Mini Displayport ● Not for use with MST Hubs. For compatibility with MST Hubs, use a Displayport 1.2 compliant product such as P586-006-VGAV2 Connects a VGA monitor to a computer with Mini Displayport with a single cable Description Tripp Lite P586-006-VGA allows you to connect a desktop or laptop computer with Mini Displayport video port, to a VGA monitor. All in one 6-ft. (1.83 m) design with inline signal converter requires no additional adapters or software....plug-and-play. It features a low profile VGA connector that fits neatly into the available monitor space, without jamming between the wall and the back of the display or impeding neighboring connectors. Resolution support up to 1920x1200. Unlike passive adapters, Active adapters convert both Single-Mode and Dual Mode (DP++) DisplayPort output. It is ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals. Features ● 6-ft. (1.83 m) Mini Displayport Male to VGA Male cable ● 1920x1200 resolution ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● Ideal for use with graphics cards, such as AMD Eyefinity, that do not output Dual Mode (DP++) signals ● Converts both Single-Mode and Dual Mode (DP++) DisplayPort output Specifications OVERVIEW UPC Code 037332180759 Technology VGA/SVGA; DisplayPort Cable Type Active VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) 1/3 Package Includes ● 6-ft. (1.83 m) Mini Displayport to Active VGA Cable, M/M 1000 Eaton Boulevard Cleveland, OH 44122 United States HDR Support No PHYSICAL Color Black Material of Construction ABS, PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0 +/- 15mm Wire Gauge (AWG) 32 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Operating Humidity Range 0% to 85%, Non-Condensing Storage Humidity Range 0% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HD15 (MALE) Connector Plating Nickel Contact Plating Gold Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No Displayport Specification 1.1a STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty Product Warranty Period (U.S. & Canada) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P586-006-VGA
物料型号:P586-006-VGA
器件简介: - 该产品为Mini DisplayPort到VGA主动适配器线缆(公对公),长度为6英尺(1.8米),符合TAA标准。 - 它允许将Mini DisplayPort电脑端口连接到VGA显示器。 - 该适配器线缆支持最高1920x1200分辨率,并且能够转换单模和双模(DP++)DisplayPort输出。
引脚分配: - 侧A - 连接器1:MIN DISPLAYPORT(公头) - 侧B - 连接器1:HD15(公头)
参数特性: - 最大支持视频分辨率:1920x1200(1080p) - HDR支持:否 - 连接器镀层:镍 - 接触镀层:金 - 是否有锁定或抓握连接器:否
功能详解: - 该适配器线缆支持即插即用,无需额外适配器或软件。 - 低轮廓VGA连接器设计,适合紧密空间,不会在墙壁和显示器之间造成阻碍或妨碍邻近连接器。 - 适用于不支持双模(DP++)信号输出的显卡,例如AMD Eyefinity显卡。
应用信息: - 适用于需要将VGA显示器连接到带有Mini DisplayPort的电脑的场景。 - 不适用于MST集线器,对于需要与MST集线器兼容的情况,请使用DisplayPort 1.2兼容产品,如P586-006-VGAV2。
封装信息: - 颜色:黑色 - 材料:ABS, PVC - 电缆外径(OD):5.0+/-15mm - 线规(AWG):32 - 电缆长度:6英尺(1.83米) - 电缆外被材料:PVC - 电缆外被等级:VW-1
P586-006-VGA 价格&库存
很抱歉,暂时无法提供与“P586-006-VGA”相匹配的价格&库存,您可以联系我们找货
