P581-006-VGA-V2
P581-006-VGA-V2
    TRIPPLITE
    P581-006-VGA-V2
P581-006-VGA-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort 1.2 to VGA Active Adapter Cable (DP with Latches to HD15 M/M), 6 ft. (1.8 m) MODEL NUMBER: P581-006-VGA-V2 Highlights ● Active adapter for use with any Displayport port ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● Supports computer video resolutions up to 1920 x 1200 ● Supports HD video resolutions up to 1920 x 1080 (1080p) ● No separate adapter required ● Nickel-plated connectors with gold-plated contacts Converts a DisplayPort v1.2 video signal for display on a VGA monitor, projector or television. Features Send High-Quality DisplayPort v1.2 Video Signals to a VGA Display ● Connects DisplayPort computer to VGA-enabled monitor, projector or TV ● Ideal for displaying video on large monitor or digital sign ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● HD15 and latching DisplayPort male connectors ● No separate adapter required Package Includes ● Vibrant, Superior Video Quality ● Supports computer video resolutions up to 1920 x 1200 ● Supports HD video resolutions up to 1920 x 1080 (1080p) ● Converts Single-Mode and Dual-Mode (DP++) DisplayPort output ● Perfect for use with graphics cards, such as AMD Eyefinity, that do not output DP++ signals Superior Materials for Superior Performance ● Double shielding with foil and braid for maximum EMI/RFI protection ● Nickel-plated connectors with gold-plated contacts for excellent conductivity ● Latching DisplayPort plug for secure connection ● Integral strain relief for long life Specifications OVERVIEW UPC Code 037332191939 Product Type Active Cable Technology VGA/SVGA; DisplayPort Cable Type Active VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/2 P581-006-VGA-V2 DisplayPort 1.2 to VGA Active Adapter Cable, 6 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating VW-1 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range 14° to 158°F (-10° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HD15 (MALE) Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS IP68 Rated No Displayport Specification 1.2 STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P581-006-VGA-V2
1. 物料型号: - 型号编号:P581-006-VGA-V2
2. 器件简介: - 这是一个DisplayPort 1.2到VGA的有源适配器线缆(DP带锁扣至HD15公对公),长度为6英尺(1.8米),符合TAA标准。它可以将DisplayPort v1.2视频信号转换为VGA显示器、投影仪或电视上的显示。
3. 引脚分配: - 侧A - 连接器1:DISPLAYPORT(公) - 侧B - 连接器1:HD15(公) - 带有锁扣或夹紧连接器:是
4. 参数特性: - 支持最高1920 x 1200的计算机视频分辨率 - 支持最高1920 x 1080(1080p)的高清视频分辨率 - 转换单模和双模(DP++)DisplayPort输出 - 双屏蔽(箔和编织)以实现最大的EMI/RFI保护 - 镀镍连接器,金镀接触点,以实现出色的导电性 - 锁扣式DisplayPort插头,确保连接安全 - 内置应力消除,延长使用寿命
5. 功能详解: - 支持将高质量的DisplayPort v1.2视频信号发送到VGA显示器 - 将DisplayPort电脑连接到VGA显示器、投影仪或电视 - 低轮廓VGA连接器适合紧凑空间,不会在墙壁和显示器之间卡住或阻碍邻近连接 - 不需要单独的适配器 - 无需为不支持DP++信号的显卡(如AMD Eyefinity)输出信号
6. 应用信息: - 适合在大型显示器或数字标牌上显示视频 - 适合与不支持DP++信号的显卡一起使用
7. 封装信息: - 颜色:黑色 - 线缆外套颜色:黑色 - 线缆外套材料:PVC - 线缆外套等级:VW-1 - 线缆长度(英尺):6 - 线缆长度(米):1.83 - 线缆长度(英寸):72 - 发货尺寸(高宽深/英寸):7.00x 9.00x0.50 - 发货尺寸(高宽深/厘米):17.78x 22.86x1.27 - 发货重量(磅):0.24 - 发货重量(千克):0.11
P581-006-VGA-V2 价格&库存
很抱歉,暂时无法提供与“P581-006-VGA-V2”相匹配的价格&库存,您可以联系我们找货
