P586-010-VGA-V2
P586-010-VGA-V2
    TRIPPLITE
    P586-010-VGA-V2
P586-010-VGA-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort 1.2 to VGA Active Adapter Cable (M/M), 10 ft. (3.1 m) MODEL NUMBER: P586-010-VGA-V2 Highlights ● Active adapter cable for use with any Mini Displayport (or Thunderbolt) port ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections ● Supports computer video resolution up to 1920 x 1200 Converts a Mini DisplayPort v1.2 video signal for display on a VGA monitor, projector or television. Features Send High-Quality Mini DisplayPort v1.2 Video Signals to a VGA Display ● Connects Mini DisplayPort (or Thunderbolt) computer to VGA-enabled monitor, projector or TV ● Ideal for displaying video on large monitor or digital sign ● ● Low-profile VGA connector fits neatly into available space; no jamming between wall and monitor or impeding neighboring connections Supports HD video resolution up to 1920 x 1080 (1080p) ● No separate adapter required ● Mini DisplayPort and HD15 male connectors ● ● No separate adapter required Nickel-plated connectors with gold-plated contacts Package Includes Vibrant, Superior Video Quality ● Supports computer video resolutions up to 1920 x 1200 ● ● Supports HD video resolutions up to 1920 x 1080 (1080p) ● Converts Single-Mode and Dual-Mode (DP++) Mini DisplayPort output ● Perfect for use with graphics cards, such as AMD Eyefinity, that don’t output DP++ signals Superior Materials for Superior Performance ● Double shielding with foil and braid for maximum EMI/RFI protection ● Nickel-plated connectors with gold-plated contacts for excellent conductivity ● Integral strain relief for long life Specifications OVERVIEW UPC Code 037332191861 Product Type Active Cable Technology VGA/SVGA; DisplayPort Cable Type Active VIDEO Max Supported Video Resolution 1920 x 1200 (1080p) HDR Support No PHYSICAL Color Black Material of Construction ABS, PVC 1/3 P586-010-VGA-V2 Mini DisplayPort 1.2 to VGA Active Adapter Cable, 10 ft. 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.0 +/- 15mm Wire Gauge (AWG) 32 Cable Length (ft.) 10 Cable Length (m) 3.05 Cable Length (in.) 120 Shipping Dimensions (hwd / in.) 8.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 20.32 x 25.40 x 1.27 Shipping Weight (lbs.) 0.44 Shipping Weight (kg) 0.20 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Operating Humidity Range 0% to 85%, Non-Condensing Storage Humidity Range 0% to 85%, Non-Condensing CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 HD15 (MALE) Connector Plating Nickel Contact Plating Gold Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No Displayport Specification 1.2 STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); REACH; RoHS; UKCA; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (U.S. & Canada) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P586-010-VGA-V2 价格&库存
很抱歉,暂时无法提供与“P586-010-VGA-V2”相匹配的价格&库存,您可以联系我们找货
