U338-000-SATA
U338-000-SATA
    TRIPPLITE
    USB3.0TOSATAIDECOMBOADAPT
U338-000-SATA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed to SATA III Adapter for 2.5 in. to 3.5 in. SATA Hard Drives MODEL NUMBER: U338-000-SATA Highlights ● SuperSpeed (5Gbps) / Hi-Speed (480 Mbps) / Full-Speed (12 Mbps) Compliant ● SATA III (6Gbps) / SATA Gen2i (3Gbps) / Gen1i (1.5Gbps) Compliant ● For 2.5 in. to 3.5 in. SATA Hard Drives ● Supports drives up to 4TB ● Compatible with Windows (up to 10), MAC, LINUX System Requirements ● Computer with USB 3.0 port ( 2.0 and 1.1 compatible, but at slower transfer speeds ) ● SATA 2.5" or 3.5" Hard Drive Package Includes ● U338-000-SATA USB 3.0 SuperSpeed to SATA III Adapter ● USB 3.0 Micro-B Cable, 2.5 ft. ● External Power Supply with NEMA 1-15P Plug ( Input: 100240V, 50/60Hz, 0.8A; Output: 12V, 2A ) Format new hard drives, or salvage data off old drives Description Tripp Lite's U338-000-SATA USB 3.0 SuperSpeed to SATA III Adapter allows connection to a Serial ATA Hard drive (2.5" / 3.5" ). Configure hard drives without having to install them first, or, pull data from a crashed computer hard drive to a new computer. The unit features a 22-Pin SATA Data + Power connector, and USB 3.0 Micro-B connector . Works with any 2.5 in. to 3.5 in. SATA Hard Drive. The U338000-SATA is compatible with Windows (up to 10) and Mac, and can be connected to older USB generation computers ( 2.0 and 1.1, at slower speeds ) Features ● USB 3.0 and below compliant ● SATA III ( 6Gbps ) and below compliant ● Supports Plug-and-Play...No Drivers or Software needed ● Supports LBA-48 bit ( Logical Block Addressing ) ● Supports USB Mass Storage Class Bulk-Only Transport ● 22-Pin SATA Data + Power connector ● Compatible with 2.5" / 3.5" SATA Hard drives ● Supports drives up to 4TB ● Compatible with Windows (up to 10), Mac, Linux Specifications OVERVIEW UPC Code 037332182135 Technology SATA/eSATA 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States POWER AC Adapter Input: 100-240V, 50/60Hz, 0.8A; Output: 12V, 2A PHYSICAL Color Black Shipping Dimensions (hwd / in.) 3.00 x 3.20 x 5.00 Shipping Dimensions (hwd / cm) 7.62 x 8.13 x 12.70 Shipping Weight (lbs.) 0.56 Shipping Weight (kg) 0.25 ENVIRONMENTAL Operating Temperature Range -4 to 140 F (-20 to 60 C) Storage Temperature Range -4 to 158 F (-20 to 70 C) CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
U338-000-SATA
1. 物料型号: - 型号:U338-000-SATA
2. 器件简介: - U338-000-SATA是一款USB 3.0 SuperSpeed到SATA III适配器,用于2.5英寸至3.5英寸SATA硬盘。它允许用户在不安装硬盘的情况下配置硬盘,或者从故障计算机硬盘中提取数据到新计算机。
3. 引脚分配: - 该适配器具有22针SATA数据+电源连接器和USB 3.0 Micro-B连接器。
4. 参数特性: - 支持USB 3.0及以下版本,SATA III(6Gbps)及以下版本。 - 支持即插即用,无需驱动程序或软件。 - 支持LBA-48位(逻辑块寻址)。 - 支持USB大容量存储类。 - 支持2.5英寸/3.5英寸SATA硬盘。 - 支持高达4TB的硬盘。 - 兼容Windows(最高10)、Mac和Linux操作系统。
5. 功能详解: - 该适配器允许连接串行ATA硬盘,支持数据传输和电源供应。 - 可以用于格式化新硬盘或从旧硬盘中恢复数据。
6. 应用信息: - 适用于需要在不同计算机之间传输数据或配置硬盘的场景。
7. 封装信息: - 颜色:黑色。 - 运输尺寸:3.00x3.20x5.00英寸(7.62x8.13x12.70厘米)。 - 运输重量:0.56磅(0.25千克)。
U338-000-SATA 价格&库存
很抱歉,暂时无法提供与“U338-000-SATA”相匹配的价格&库存,您可以联系我们找货
