S455-006
S455-006
    TRIPPLITE
    S455-006
S455-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SCSI Ultra2/U160/U320 LVD Cable (VHDCI to HD68 M/M), 6-ft. Highlights ● Premium double-shielded cable ● Meets the most current SCSI specifications for high-speed devices MODEL NUMBER: S455-006 System Requirements ● Any external SCSI device or host controller card requiring VHDCI68 or HD68 interface Package Includes ● Description Moving your network into the next phase of SCSI solutions? Look no further than Tripp Lite's brand of SCSI U320/U160 cables. Supports all legacy transfer rates including Ultra 320 . Multi-platform SCSI III external peripheral cable, VHDCI68M/HD68M. This 6ft cable is designed to connect two SCSI III (fast and wide) or SCSI II devices together. Manufactured using double shielded 34 twisted pair high impedance cable. Constructed with low-capacitance, impedance matched, 28 AWG, stranded, tinned copper cable with insulated in polypropylene. Features ● Supports all SCSI transfer rates through 320Mbps ● LVD/SE compliant ● Backwards compatibility with previous SCSI generations ● Double shielded (foil and braid) ● 34 twisted pair conductors ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest Ultra 320 to legacy SCSI-1 and every combination in between Specifications OVERVIEW UPC Code 037332121332 Technology SCSI PHYSICAL Color Black 1/2 6-ft. SCSI U320/U160 LVD/SE cable, VHDCI68M to HD68M 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 8.50 x 6.90 x 0.50 Shipping Dimensions (hwd / cm) 21.59 x 17.53 x 1.27 Shipping Weight (lbs.) 0.73 Shipping Weight (kg) 0.33 CONNECTIONS Side A - Connector 1 VHDCI68 (MALE) Side B - Connector 1 HD68 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
S455-006
物料型号为 S455-006,是 Tripp Lite 系列的 SCSI Ultra2/U160/U320 LVD 电缆,具有 VHDCI 到 HD68 公对公的接口,长度为 6 英尺。
器件简介:这款电缆支持所有 SCSI 传输速率,包括 Ultra 320,并且兼容多平台 SCSI III 外部设备。
它使用双屏蔽 34 对绞线高阻抗电缆制造,具有低电容、阻抗匹配的特性。
引脚分配:电缆的 Side A 连接器为 VHDCI68(公),Side B 连接器为 HD68(公)。
参数特性:电缆长度为 6 英尺(1.83 米),颜色为黑色,UPC 编码为 037332121332,技术为 SCSI。
功能详解:电缆支持所有 SCSI 传输速率,包括 320Mbps,符合 LVD/SE 标准,并且与之前的 SCSI 代兼容。
它还具有双屏蔽(箔和编织层)和 34 对绞线导体。
应用信息:适用于任何需要 VHDCI68 或 HD68 接口的外部 SCSI 设备或主机控制器卡。
封装信息:电缆的发货尺寸为 8.50x6.90x0.50 英寸(21.59x17.53x1.27 厘米),发货重量为 0.73 磅(0.33 公斤)。
产品提供全球范围内的有限终身保修。
S455-006 价格&库存
很抱歉,暂时无法提供与“S455-006”相匹配的价格&库存,您可以联系我们找货
