P566-050
P566-050
    TRIPPLITE
    P566-050
P566-050 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI to DVI Adapter Cable (M/M), 50 ft. (15.2 m) Highlights ● Premium double shielded digital video cable protects against EMI/RFI noise. ● Gold plated connectors and contacts provide optimal signal transfer. ● Supports high-def video resolutions up to 1920 x 1080 @60Hz (1080p). ● Supports a bandwidth up to 5Gbps ● This product is covered by a Lifetime Limited Warranty MODEL NUMBER: P566-050 Package Includes ● Creates a pure bi-directional digital connection between a DVI-enabled source and an HDMI-enabled display or an HDMI-enabled source and DVI-enabled display. Description Tripp Lite's 50-ft. (15.24 m) DVI - HDMI ( High Definition Multimedia Interface ) cable allows interconnection between digital display devices, such as DTV's ( Digital Television ), Plasma displays, LCD TV's, and projectors, to Digital source devices, such as Digital Set-Top boxes, DVD/DVD-R players, and AV receivers. HDMI DTV's will display video received from existing DVI-equipped products, and DVIequipped TVs will display video from HDMI sources. The DVI-HDMI adapter does not support audio. Features ● 50-ft. (15.24 m) HDMI to DVI-D Single Link Adapter Cable ● Creates a pure bi-directional digital connection between a DVI-enabled source and an HDMI-enabled display or an HDMI-enabled source and a DVI-enabled display. ● Gold plated connectors and contacts provide optimal signal transfer ● Premium Double-Shielded HDMI compliant cable protects against outside noise (EMI/RFI) ● Impedance matched twisted pair construction reduces cross-talk and interference ● Supports High-Definition (HD) video resolutions up to 1920 x 1080 @60Hz (1080p). Specifications OVERVIEW UPC Code 037332181336 Product Type Passive Cable Technology DVI; HDMI Cable Type Passive VIDEO 1/2 50-ft. (15.24 m) HDMI to DVI Gold Digital Video Cable HDMI-M/DVI-M 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 1920 x 1200 (1080p) PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Length (ft.) 50 Cable Length (m) 15.24 Cable Length (in.) 600 Shipping Dimensions (hwd / in.) 1.50 x 6.80 x 7.80 Shipping Dimensions (hwd / cm) 3.81 x 17.27 x 19.81 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 DVI-D SINGLE LINK (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P566-050
1. 物料型号: - 型号编号:P566-050 - 产品类型:被动线缆 - 技术:DVI; HDMI
2. 器件简介: - 该产品为HDMI至DVI适配器线缆(公/母),长度为50英尺(15.2米),支持高清视频分辨率高达1920 x 1080 @60Hz(1080p)。
3. 引脚分配: - Side A - 连接器1:HDMI(公) - Side B - 连接器1:DVI-D单链接(公) - 该适配器不支持音频。
4. 参数特性: - 最大支持视频分辨率:1920x1200(1080p) - 支持带宽高达5Gbps - 产品覆盖终身有限保修
5. 功能详解: - 该DVI-HDMI线缆允许数字显示设备(如高清电视和投影仪)与数字源设备(如卫星/有线电视盒、蓝光播放器和AV接收器)之间的互连。 - HDMI电视将显示来自现有DVI设备的视讯,DVI电视将显示来自HDMI源的视讯。 - 该DVI-HDMI适配器不支持音频。
6. 应用信息: - 该线缆创建了一个纯双向数字连接,可以在DVI启用的源和HDMI启用的显示器之间,或者HDMI启用的源和DVI启用的显示器之间进行连接。
7. 封装信息: - 颜色:黑色 - 电缆外皮材料:PVC - 电缆外皮等级:VW-1 - 电缆长度:50英尺(15.24米) - 运输尺寸:1.50x6.80x7.80英寸 - 运输重量:1.80磅(0.82公斤)
P566-050 价格&库存
很抱歉,暂时无法提供与“P566-050”相匹配的价格&库存,您可以联系我们找货
