M100-10N-BK-10
M100-10N-BK-10
    TRIPPLITE
    CABLE
M100-10N-BK-10 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB-A to Lightning Sync/Charge Cable, MFi Certified - Black, M/M, USB 2.0, 10 Pack - 10 in. (0.3m) MODEL NUMBER: M100-10N-BK-10 Highlights ● 10 piece bulk pack ● Features a reversible 8-pin Lightning plug and a USB-A plug ● MFi-certified for broad compatibility with your Apple iPhone, iPad or iPod ● Compatible with all devices with 8-pin connectors ● Plugs into Apple device in either direction Applications This USB Type-A to Lightning cable connects your iPhone, iPad or iPod device to the USB port on your computer or wall/car charger Features Tripp Lite's M100-10N-BK-10 is a 10-piece bulk pack of 10-inch black USB Sync / Charge Cable with Lightning connector allows for uploading and downloading data, while charging the devices at the same time. Cable is MFi-certified for use with the latest generation of iPhone, iPad and iPod devices. Reversible Lightning connector allows plug-ability in either direction to the device. Specifications OVERVIEW UPC Code 037332188526 Technology Lightning; USB; USB 2.0 (High Speed) Cable Type Passive INPUT Maximum Input Amps 2 POWER USB Power Delivery (PD) Charging Support No 1/3 ● Charge and sync your Apple iPhone, iPad or iPod using the USB-A port on your computer or a wall charger ● Transfer photos and other important files between an external hard drive and your Apple device System Requirements ● Device or charger with USB-A port ● Most current iPhone, iPad and iPod devices Package Includes ● M100-10N-BK USB Sync/Charge Cable with Apple Lightning Connector, 10 Pack 1000 Eaton Boulevard Cleveland, OH 44122 United States CHARGING Total Charging Watts 12 PHYSICAL Material of Construction PVC Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 2.8mm Wire Gauge (AWG) 30/24 Cable Length (ft.) 0.8 Cable Length (m) 0.24 Cable Length (in.) 10 Shipping Dimensions (hwd / in.) 1.25 x 2.80 x 5.25 Shipping Dimensions (hwd / cm) 3.18 x 7.11 x 13.34 Shipping Weight (lbs.) 0.26 Shipping Weight (kg) 0.12 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range -4° to 140°F (-20° to 60°C) Storage Temperature Range -4° to 176°F (-20° to 80°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing Power Provided to Connected Device(s) 12W (5V/2.4A) CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 LIGHTNING (MALE) Connector Plating Nickel Contact Plating Gold FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Data Transfer Rate 480 Mbps Angled Plug No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Product Certifications MFi Product Compliance RoHS; REACH; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
M100-10N-BK-10 价格&库存
很抱歉,暂时无法提供与“M100-10N-BK-10”相匹配的价格&库存,您可以联系我们找货
M100-10N-BK-10
库存:10
