P106-06I
P106-06I
    TRIPPLITE
    ADAPTER DIN5F TO PS/2M 6"
P106-06I 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 6-inch AT to PS/2 Keyboard Adapter (DIN5F/MiniDIN6M) Highlights ● Short pigtail adapter (6 inch) ● Use this adapter to convert an AT style keyboard for use with PS/2 style port ● Converts a DIN5 female port to a male PS/2 for (MD6 male) MODEL NUMBER: P106-06I System Requirements ● Computer with a PS/2 style connector (MiniDin6F) ● Keyboard with an AT style plug (Din5M) Package Includes ● Description This gender changer allows the customer to use an AT style keyboard in a PS/2 slot. This converter will work with any AT style keyboard. Gold plated copper contacts provide maximum conductivity with no data loss. An aluminum undermold shield meets FCC requirements on EMI/RFI protection. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. The 6 inch pigtail allows for easy installation of the device. Features ● Connect a keyboard with an AT style adapter to a computer with a PS/2 style connector ● 6-in length ● Connector type: DIN5 (female) to MiniDIN6 (male) ● Tripp Lite warrants this product to be free from defects in materials and workmanship for life Specifications OVERVIEW UPC Code 037332011688 Technology PS/2 PHYSICAL Color Beige Shipping Dimensions (hwd / in.) 6.75 x 4.00 x 0.75 Shipping Dimensions (hwd / cm) 17.14 x 10.16 x 1.90 Shipping Weight (lbs.) 0.62 1/2 6-in. AT to PS2 Keyboard Adapter DIN5F to DIN6M 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.28 CONNECTIONS Side A - Connector 1 DIN-5 (FEMALE) Side B - Connector 1 MINI DIN-6 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P106-06I
物料型号:P106-06I
器件简介: - 这是一个6英寸的AT到PS/2键盘适配器(DIN5F/MiniDIN6M),可以将AT样式的键盘转换为PS/2样式的端口使用。
引脚分配: - 该适配器将DIN5(女头)转换为MiniDIN6(公头)。
参数特性: - 物理尺寸:17.14x10.16x1.90厘米(长x宽x高) - 运输重量:0.62磅(约0.28千克)
功能详解: - 该适配器允许用户在PS/2插槽中使用AT样式的键盘。 - 适配器长度为6英寸,便于安装。 - 镀金铜接触点提供最大导电性,无数据丢失。 - 铝制下模屏蔽满足FCC对EMI/RFI保护的要求。
应用信息: - 适用于带有PS/2样式连接器(MiniDin6F)的计算机。 - 适用于带有AT样式插头(Din5M)的键盘。
封装信息: - Tripp Lite为该产品提供终身有限保修,保证材料和工艺无缺陷。
P106-06I 价格&库存
很抱歉,暂时无法提供与“P106-06I”相匹配的价格&库存,您可以联系我们找货
