P604-010
P604-010
    TRIPPLITE
    CABLE PARALLEL DB25M -CEN36M 10'
P604-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Cable, 10-ft. Premium Bi-Directional Parallel Cable, Cen36M to DB25M Highlights ● Superior molded cables with integral strain relief and foilshielding for maximum EMI/RFI protection ● Provides superior conductivity and support for high-speed bidirectional printing MODEL NUMBER: P604-010 System Requirements ● Computers with a DB25 Female parallel port ● Parallel printers with a Centronics 36 Female parallel port with Bi-Directional communication (although not essential). Package Includes ● Description Tripp Lite's 10-ft. premium bi-directional parallel printer cable connects computers with a DB25 female parallel port to parallel printers with a Centronics 36 female parallel port. The cable has DB25 male/Cent36 male connectors and supports bi-directional communication. It is manufactured from superior molded cable with integral strain relief and foil shielding for maximum EMI/RFI protection. Bi-directional communication allows your printer to broadcast printer error messages back to network computers. Use IEEE cable if IEEE specifications are required. Tripp Lite warrants this product to be free from defects in materials and workmanship for life. Features ● Supports bi-directional communication ● Length: 10-ft. Connectors: DB25 male/Cent36 male ● Premium molded cable with integral strain relief and foil shielding for maximum EMI/RFI protection ● Bi-directional communication allows your printer to broadcast printer error messages back to network computers ● Molded ends with easy-grip textured overmold ● Use IEEE cable if IEEE specifications are required Specifications OVERVIEW UPC Code 037332013484 PHYSICAL Cable Length (ft.) 10 Cable Length (m) 3.05 1/2 10-ft. Premium Bidir Parallel Cable Cen36M to DB25M 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 11.75 x 7.00 x 1.00 Shipping Dimensions (hwd / cm) 29.84 x 17.78 x 2.54 Shipping Weight (lbs.) 0.73 Shipping Weight (kg) 0.33 CONNECTIONS Side A - Connector 1 DB25 (MALE) Side B - Connector 1 CENTRONICS 36 (MALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P604-010
物料型号: - 型号编号:P604-010
器件简介: - Tripp Lite系列的10英尺高级双向并行电缆,一端为Cen36M,另一端为DB25M,用于连接计算机的DB25 Female并行端口和并行打印机的Centronics 36 Female并行端口。
引脚分配: - 连接器1(Side A):DB25 Male - 连接器1(Side B):CENTRONICS 36 Male
参数特性: - 支持双向通信 - 长度:10英尺(3.05米) - 电缆类型:高级成型电缆,内置抗拉设计和箔屏蔽,以实现最大的EMI/RFI保护 - 双向通信允许打印机将错误信息广播回网络计算机
功能详解: - 该电缆支持双向通信,允许打印机向网络计算机发送错误信息。 - 采用高级成型电缆,内置抗拉设计和箔屏蔽,以提供最大的EMI/RFI保护。 - 两端都有易于握持的纹理覆盖成型端。
应用信息: - 适用于需要高速双向打印支持的计算机和并行打印机。 - 如果需要符合IEEE规范,请使用IEEE电缆。
封装信息: - 产品保修期:终身有限保修 - UPC代码:037332013484 - 发货尺寸(长宽高/英寸):11.75x7.00x1.00 - 发货尺寸(长宽高/厘米):29.84x17.78x2.54 - 发货重量(磅):0.73 - 发货重量(千克):0.33
P604-010 价格&库存
很抱歉,暂时无法提供与“P604-010”相匹配的价格&库存,您可以联系我们找货
