1000 Eaton Boulevard
Cleveland, OH 44122
United States
DisplayPort Cable with Latching Connectors, 4K
60 Hz (M/M), Black, 10 ft. (3.05 m)
MODEL NUMBER: P580-010
Highlights
Digital Video and Audio in one
cable
Small footprint compared to
VGA or DVI
Supports Ultra High Definition
(UHD) 4K x 2K video resolutions
up to 3840 x 2160 @ 60Hz,
including 1080p
Package Includes
Features
The future standard for Digital Video and Audio connections
Supports Displayport v1.2
Supports High Definition Content Protection ( HDCP )
Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz, including
1080p
Specifications
OVERVIEW
UPC Code
037332145956
Product Type
Passive Cable
Technology
DisplayPort
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 60Hz
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:2:0; 4:2:2
Signal Transmission
Bidirectional
1/3
DisplayPort to DisplayPort
Cable 4K with Latches (M/M),
10 ft.
Cleveland, OH 44122
United States
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
10
Cable Length (m)
3.05
Cable Length (in.)
120
Ferrite Core
No
Minimum Bend Radius
60mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.35
Shipping Weight (kg)
0.16
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
No
CONNECTIONS
Side A - Connector 1
DISPLAYPORT (MALE)
Side B - Connector 1
DISPLAYPORT (MALE)
Connector Plating
Nickel
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
Yes
FEATURES & SPECIFICATIONS
2/3
Cleveland, OH 44122
United States
EMI/RFI Line Noise Protection
No
MST Support
Yes
Antibacterial
No
IP68 Rated
No
Armored Cable
No
Ethernet Support
No
Displayport Specification
1.2
HDCP Specification
2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P580-010”相匹配的价格&库存,您可以联系我们找货
