1000 Eaton Boulevard
Cleveland, OH 44122
United States
Mini DisplayPort Cable, 4K 60Hz (M/M), White, 6
ft. (1.8 m)
MODEL NUMBER: P584-006
Highlights
6-ft. (1.83 m) Mini Displayport to
Mini Displayport Cable
Connect your PC or Mac with
Mini Displayport (or
Thunderbolt) to a Mini
Displayport Monitor or TV
Supports Displayport v1.2
Supports Ultra High Definition
(UHD) 4K x 2K video resolutions
up to 3840 x 2160 @ 60Hz,
including 1080p
Package Includes
Features
6ft Mini Displayport to Mini Displayport cable
Connect your PC or Mac with Mini Displayport (or Thunderbolt) to a Mini Displayport Monitor or TV
Supports HDCP Pass-Through
Compatible with all Mini Displayport computers and peripherals
Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz, including
1080p
Specifications
OVERVIEW
UPC Code
037332174628
Product Type
Passive Cable
Technology
DisplayPort
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 60Hz
Max Supported Color Depth
24-bit True Color
HDR Support
No
3D Video Supported
Yes
1/3
Cleveland, OH 44122
United States
Chroma Sub Sampling
4:2:0; 4:2:2
Signal Transmission
Bidirectional
PHYSICAL
Color
White
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.8 mm
Wire Gauge (AWG)
32
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Ferrite Core
No
Minimum Bend Radius
48mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.13
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
32° to 113°F (0° to 45°C)
Storage Temperature Range
-40° to 158°F (-40° to 70°C)
Operating Humidity Range
10% to 85% RH, Non-Condensing
Storage Humidity Range
5% to 90% RH, Non-Condensing
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
No
CONNECTIONS
Side A - Connector 1
MINI DISPLAYPORT (MALE)
Side B - Connector 1
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
2/3
Cleveland, OH 44122
United States
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
Yes
Antibacterial
No
IP68 Rated
No
Armored Cable
No
Ethernet Support
No
Displayport Specification
1.2
HDCP Specification
2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH; WEEE
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P584-006”相匹配的价格&库存,您可以联系我们找货
