P568-003-FL
P568-003-FL
    TRIPPLITE
    P568-003-FL
P568-003-FL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Flat Cable, Digital Video with Audio, UHD 4K (M/M), Black, 3 ft. (0.91 m) MODEL NUMBER: P568-003-FL Highlights ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● High Speed HDMI and HDCP compliant ● Supports Ultra High Definition (UHD) 4K video resolutions Package Includes ● Description Tripp Lite's 3-ft. (0.91 m) Flat High Speed HDMI (High Definition Multimedia Interface) Gold Cable allows interconnection between digital display devices, such as DTV's (digital television), plasma displays, LCD TV's, and projectors, to Digital source devices, such as digital set-top boxes, Blu-Ray players, and AV receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. Utilizing a flat design, each individual inner conductor is organized differently to reduce cross-talk between the wires, which produces a cleaner signal than round HDMI cables. Flat HDMI cables also fit closer to walls and better around bends and turns, as well as under carpeting. Features ● Flat design for better manageability ● Flat conductors reduce crosstalk and inductance ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations ● Supports Ultra High Definition (UHD) 4K video resolutions Specifications OVERVIEW UPC Code 037332137968 Product Type Passive Cable 1/4 3-ft. (0.91 m) Flat High Speed HDMI Gold Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.0*12.0mm Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Ferrite Core No Minimum Bend Radius 30mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.13 Shipping Weight (kg) 0.06 ENVIRONMENTAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 176°F (-40° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P568-003-FL 价格&库存
很抱歉,暂时无法提供与“P568-003-FL”相匹配的价格&库存,您可以联系我们找货
P568-003-FL
    • 1+92.941341+11.99689
    • 10+78.9953210+10.19674
    • 25+74.0445225+9.55769
    • 50+70.5092150+9.10135
    • 100+67.14425100+8.66700
    • 250+62.94255250+8.12464
    • 500+59.94098500+7.73720
    • 1000+57.921971000+7.47658
    库存:98
