P570-003-MICRO
P570-003-MICRO
    TRIPPLITE
    P570-003-MICRO
P570-003-MICRO 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI to Micro HDMI Cable with Ethernet, Digital Video with Audio Adapter (M/M), 3 ft. (0.91 m) MODEL NUMBER: P570-003-MICRO Highlights ● 3-ft. (0.91 m) HDMI to Micro HDMI High Speed w/Ethernet Cable ● Micro HDMI connector is 50% smaller than standard HDMI ● Complies with HDMI v1.4 Type D connections ● Full 1080p, 3D, Blu-Ray, Ethernet, Digital Audio transfer System Requirements ● Device with Micro-HDMI output, to Display with standard HDMI Input Package Includes ● Description Tripp Lite's 3-ft. (0.91 m), HDMI to Micro HDMI High Speed w/Ethernet Audio/Video cable allow devices with Micro-HDMI output ports, such as Smart Phones, Cameras, Notebooks, and other portable devices, to attach to standard HDMI displays such as TV's, monitors, Projectors, etc. Cable complies with HDMI v1.4 specifications, and is capable of transferring 1080p, Ethernet, 3D video, as well as digital audio. Featuring a full 19-pin array like larger HDMI connectors, only in a miniaturized version, the HDMI Micro Connector saves space on portable devices, while allowing the full capabilities of current HDMI v1.4 digital signaling. Features ● 3-ft. (0.91 m) HDMI to Micro HDMI High Speed w/Ethernet Cable ● Compliant with HDMI v1.4 specifications, Type D Connector ● 1080p, 3D, Blu-Ray, Ethernet, Digital Audio transfer ● Mylar Foil and Braid Shielding for maximum noise suppression ● Rugged, molded connectors for a lifetime of use ● Gold plated contacts and connector shell assures highest signal quality Specifications OVERVIEW UPC Code 037332165473 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO 1/3 3-ft. (0.91 m) HDMI to Micro HDMI High Speed w/Ethernet Audio/Video Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Max Supported Video Resolution 1920 x 1200 (1080p) Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.5 mm Wire Gauge (AWG) 34 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Ferrite Core No Minimum Bend Radius 22.5mm Shipping Dimensions (hwd / in.) 0.25 x 4.70 x 9.10 Shipping Dimensions (hwd / cm) 0.64 x 11.94 x 23.11 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 MICRO HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P570-003-MICRO 价格&库存
很抱歉,暂时无法提供与“P570-003-MICRO”相匹配的价格&库存,您可以联系我们找货
