P568-006
P568-006
    TRIPPLITE
    P568-006
P568-006 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI Cable, Digital Video with Audio, UHD 4K (M/M), Black, 6 ft. (1.83 m) MODEL NUMBER: P568-006 Highlights ● Premium double-shielded digital audio/video cable ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● High Speed HDMI and HDCP compliant ● Supports Ultra High Definition (UHD) 4K video resolutions Package Includes ● Features ● Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled digital video sources ● Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter ● Gold-plated connectors provide optimal signal transfer ● Premium double-shielded cable protects against outside noise (EMI/RFI) ● Impedance-matched twisted-pair construction reduces cross-talk and interference ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations ● Supports Ultra High Definition (UHD) 4K video resolutions Specifications OVERVIEW UPC Code 037332122933 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 24-bit True Color HDR Support No 1/3 6-ft High Speed HDMI Gold Cable 1000 Eaton Boulevard Cleveland, OH 44122 United States 3D Video Supported No Chroma Sub Sampling 4:4:4 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 5.5 mm Wire Gauge (AWG) 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Ferrite Core No Minimum Bend Radius 55mm Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.22 Shipping Weight (kg) 0.10 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 176°F (-40° to 80°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support No HDCP Specification 1.3 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P568-006 价格&库存
很抱歉,暂时无法提供与“P568-006”相匹配的价格&库存,您可以联系我们找货
