P571-003-MINI
P571-003-MINI
    TRIPPLITE
    P571-003-MINI
P571-003-MINI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI to Mini HDMI Cable with Ethernet (M/M), 3 ft. MODEL NUMBER: P571-003-MINI Highlights ● Supports UHD resolutions up to 4K (4:4:4) for crystal-clear video ● Premium foil and braid shielding protects against EMI/RFI noise ● 24K gold-plated connectors for maximum conductivity Package Includes High Speed with Ethernet HDMI to Mini-HDMI Cable, 3 ft. Description Tripp Lite's three-foot HDMI to Mini-HDMI cable allows you to connect digital cameras, camcorders and other digital devices with the Mini-HDMI connector directly to your standard HDMI-enabled TV. This cable offers the same baseline performance as standard high-speed HDMI cables (including 1080p video resolution), plus an additional dedicated data channel, known as the HDMI Ethernet Channel, for device networking. HDMI Ethernet Channel functionality is only available if both linked devices are HDMI Ethernet Channel-enabled. Cable supports not only the Ethernet component, but also 3D and Audio Return Channel. Features Connects Mini-HDMI and HDMI Devices ● Recommended for mobile users who want a cable that can easily pack away in a backpack, laptop bag or camera bag ● Ideal for connecting a mini-HDMI camcorder, digital camera or tablet to an HDMI display High Performance and Wide Compatibility ● Supports HD video resolutions up to 1080p ● Superior Quality Ensures a Flawless Signa ● 24K gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332175595 Product Type Passive Cable 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4; 4:2:2 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0 mm Wire Gauge (AWG) 30 Cable Length (ft.) 3 Cable Length (m) 0.91 Cable Length (in.) 36 Ferrite Core No Minimum Bend Radius 60mm Shipping Dimensions (hwd / in.) 8.50 x 7.00 x 0.20 Shipping Dimensions (hwd / cm) 21.59 x 17.78 x 0.51 Shipping Weight (lbs.) 0.14 Shipping Weight (kg) 0.06 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32° to 140°F (0° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 30% to 90% RH, Non-Condensing Storage Humidity Range 30% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 MINI HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P571-003-MINI 价格&库存
很抱歉,暂时无法提供与“P571-003-MINI”相匹配的价格&库存,您可以联系我们找货
