1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDMI to Micro HDMI Cable with Ethernet, Digital
Video with Audio Adapter (M/M), 6 ft. (1.83 m)
MODEL NUMBER: P570-006-MICRO
Highlights
6ft HDMI to Micro HDMI High
Speed w/Ethernet Cable
Micro HDMI connector is 50%
smaller than standard HDMI
Complies with HDMI v1.4 Type
D connections
Full 1080p, 3D, Blu-Ray,
Ethernet, Digital Audio transfer
System Requirements
Device with Micro-HDMI output,
to Display with standard HDMI
Input
Package Includes
Description
Tripp Lite's 6-ft. (1.83 m), HDMI to Micro HDMI High Speed w/Ethernet Audio/Video cable allow devices
with Micro-HDMI output ports, such as Smart Phones, Cameras, Notebooks, and other portable devices,
to attach to standard HDMI displays such as TV's, monitors, Projectors, etc. Cable complies with HDMI
v1.4 specifications, and is capable of transferring 1080p, Ethernet, 3D video, as well as digital audio.
Featuring a full 19-pin array like larger HDMI connectors, only in a miniaturized version, the HDMI Micro
Connector saves space on portable devices, while allowing the full capabilities of current HDMI v1.4 digital
signaling.
Features
6-ft. (1.83 m) HDMI to Micro HDMI High Speed w/Ethernet Cable
Compliant with HDMI v1.4 specifications, Type D Connector
1080p, 3D, Blu-Ray, Ethernet, Digital Audio transfer
Mylar Foil and Braid Shielding for maximum noise suppression
Rugged, molded connectors for a lifetime of use
Gold plated contacts and connector shell assures highest signal quality
Specifications
OVERVIEW
UPC Code
037332165503
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
1/3
Audio/Video Cable
Cleveland, OH 44122
United States
Max Supported Video Resolution
1920 x 1200 (1080p)
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
4.5 mm
Wire Gauge (AWG)
34
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Ferrite Core
No
Minimum Bend Radius
22.5mm
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
2/3
Cleveland, OH 44122
United States
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
MICRO HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
Yes
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P570-006-MICRO”相匹配的价格&库存,您可以联系我们找货
