1000 Eaton Boulevard
Cleveland, OH 44122
United States
High Speed HDMI Cable with Ethernet, UHD 4K,
Digital Video with Audio (M/M), 3 ft. (0.91 m)
MODEL NUMBER: P569-003
Highlights
3-ft. (0.91 m) High Speed with
Ethernet HDMI cable v1.4
Supports transmission speeds
up to 18 Gbps
Backward compatible to
previous HDMI generations
Video mirroring with iPad2
System Requirements
HDMI video source and HDMI
enabled TV / Monitor
Package Includes
Features
3-ft. (0.91 m) High Speed with Ethernet HDMI cable v1.4
Supports transmission speeds up to 18 Gbps
Backward compatible to previous HDMI generations
Fully molded cables, with Gold plated connectors assures long life
Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the
web and display presentations
Specifications
OVERVIEW
UPC Code
037332160645
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 30Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
1/3
Ethernet HDMI Cable v1.4
Cleveland, OH 44122
United States
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
6.0 mm
Wire Gauge (AWG)
30
Cable Length (ft.)
3
Cable Length (m)
0.91
Cable Length (in.)
36
Ferrite Core
No
Minimum Bend Radius
30mm
Shipping Dimensions (hwd / in.)
9.10 x 7.20 x 0.50
Shipping Dimensions (hwd / cm)
23.11 x 18.29 x 1.27
Shipping Weight (lbs.)
0.19
Shipping Weight (kg)
0.09
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
2/3
Cleveland, OH 44122
United States
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
Yes
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P569-003”相匹配的价格&库存,您可以联系我们找货
