P584-003
P584-003
    TRIPPLITE
    P584-003
P584-003 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini DisplayPort Cable, 4K 60 Hz (M/M), White, 3 ft. (0.9 m) MODEL NUMBER: P584-003 Highlights ● 3-ft. (0.91 m) Mini Displayport to Mini Displayport Cable ● Connect your PC or Mac with Mini Displayport (or Thunderbolt) to a Mini Displayport Monitor or TV ● Supports Displayport v1.2 ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz, including 1080p Package Includes ● Features ● 3-ft. (0.91 m) Mini Displayport to Mini Displayport cable ● Supports Displayport v1.2 ● Connect your PC or Mac with Mini Displayport (or Thunderbolt) to a Mini Displayport Monitor or TV ● Supports HDCP Pass-Through ● Compatible with all Mini Displayport computers and peripherals ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 60Hz, including 1080p Specifications OVERVIEW UPC Code 037332174611 Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2 1/3 3-ft. (0.91 m) Mini Displayport to Mini Displayport cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Signal Transmission Bidirectional PHYSICAL Color White Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 4.8 mm Wire Gauge (AWG) 32 Cable Length (ft.) 3 Cable Length (m) 0.91 Ferrite Core No Minimum Bend Radius 48mm Shipping Dimensions (hwd / in.) 6.00 x 4.00 x 0.50 Shipping Dimensions (hwd / cm) 15.24 x 10.16 x 1.27 Shipping Weight (lbs.) 0.07 Shipping Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range -40 to 158 F (-40 to 70 C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 MINI DISPLAYPORT (MALE) Side B - Connector 1 MINI DISPLAYPORT (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States EMI/RFI Line Noise Protection No MST Support Yes Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P584-003 价格&库存
很抱歉,暂时无法提供与“P584-003”相匹配的价格&库存,您可以联系我们找货
