P571-006-MINI
P571-006-MINI
    TRIPPLITE
    P571-006-MINI
P571-006-MINI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High-Speed HDMI to Mini HDMI Cable with Ethernet (M/M), 6 ft. MODEL NUMBER: P571-006-MINI Highlights ● Supports UHD resolutions up to 4K (4:4:4) for crystal-clear video ● Premium foil and braid shielding protects against EMI/RFI noise ● 24K gold-plated connectors for maximum conductivity Package Includes High Speed with Ethernet HDMI to Mini-HDMI Cable, 6 ft. Description Tripp Lite's six-foot HDMI to Mini-HDMI cable allows you to connect digital cameras, camcorders and other digital devices with the Mini-HDMI connector directly to your standard HDMI-enabled TV. This cable offers the same baseline performance as standard high-speed HDMI cables (including 1080p video resolution), plus an additional dedicated data channel, known as the HDMI Ethernet Channel, for device networking. HDMI Ethernet Channel functionality is only available if both linked devices are HDMI Ethernet Channel-enabled. Cable supports not only the Ethernet component, but also 3D and Audio Return Channel. Features Connects Mini-HDMI and HDMI Devices ● Recommended for mobile users who want a cable that can easily pack away in a backpack, laptop bag or camera bag ● Ideal for connecting a mini-HDMI camcorder, digital camera or tablet to an HDMI display High Performance and Wide Compatibility ● Supports HD video resolutions up to 1080p ● Superior Quality Ensures a Flawless Signa ● 24K gold-plated connectors and contacts for maximum conductivity and minimum data loss ● Integral strain relief protects cable and connectors from stress and cracking ● Foil and braid shielding protects against EMI/RFI line noise that can distort or destroy data ● Flexible PVC jacket easy to install in tight spaces Specifications OVERVIEW UPC Code 037332175601 Product Type Passive Cable 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4; 4:2:2 EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification Stereo Audio USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 6.0 mm Wire Gauge (AWG) 30 Cable Length (ft.) 6 Cable Length (m) 1.83 Cable Length (in.) 72 Ferrite Core No Minimum Bend Radius 60mm Shipping Dimensions (hwd / in.) 0.25 x 7.00 x 7.00 Shipping Dimensions (hwd / cm) 0.64 x 17.78 x 17.78 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32° to 140°F (0° to 60°C) Storage Temperature Range -4° to 140°F (-20° to 60°C) Operating Humidity Range 30% to 90% RH, Non-Condensing Storage Humidity Range 30% to 90% RH, Non-Condensing COMMUNICATIONS Consumer Electronics Control (CEC) Supported Yes CONNECTIONS Side A - Connector 1 MINI HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P571-006-MINI
1. 物料型号: - 型号编号:P571-006-MINI
2. 器件简介: - 这款HDMI转Mini HDMI线缆支持高清视频分辨率,最高可达4K(4:4:4),提供清晰的视频效果。它具备高级箔和编织屏蔽,以防止电磁干扰/射频干扰噪声,24K镀金连接器以实现最大导电性。包装内包含高速以太网HDMI转Mini-HDMI线缆,长度为6英尺。
3. 引脚分配: - 侧A - 连接器1:MINI HDMI(公头) - 侧B - 连接器1:HDMI(公头)
4. 参数特性: - 最大支持视频分辨率:3840x2160(4K)@ 30Hz - 最大支持色深:48位深色 - HDR支持:否 - 支持3D视频:是 - 色度子采样:4:4:4:4:2:2 - EDID支持:是 - 信号传输:双向 - 音频规格:立体声音频 - 连接器镀层:镍 - 接触镀层:24K金 - 连接器样式:直头 - 是否有锁扣或握持连接器:否
5. 功能详解: - 该线缆允许将数字相机、摄像机和其他带有Mini-HDMI连接器的数字设备直接连接到标准HDMI电视。除了支持1080p视频分辨率等标准高速HDMI线缆的基线性能外,还额外提供了一个专用数据通道,即HDMI以太网通道,用于设备网络连接。HDMI以太网通道功能只有在两个连接设备都支持HDMI以太网通道时才可用。该线缆不仅支持以太网组件,还支持3D和音频回传通道。
6. 应用信息: - 推荐给想要一个可以轻松放入背包、笔记本电脑包中的线缆的移动用户。 - 非常适合连接Mini-HDMI摄像机、数码相机或平板电脑到HDMI显示器。
7. 封装信息: - 颜色:黑色 - 电缆外径(OD):6.0mm - 线规(AWG):30 - 电缆长度(英尺):6 - 电缆长度(米):1.83 - 电缆长度(英寸):72 - 最小弯曲半径:60mm - 电缆外被材料:PVC - 电缆外被等级:VW-1
P571-006-MINI 价格&库存
很抱歉,暂时无法提供与“P571-006-MINI”相匹配的价格&库存,您可以联系我们找货
