P560-025
P560-025
    TRIPPLITE
    P560-025
P560-025 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DVI Dual Link Cable, Digital TMDS Monitor Cable (DVI-D M/M), 25 ft. (7.62 m) MODEL NUMBER: P560-025 Highlights ● For use with Dual or Single TMDS Link specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 2560 x 1600 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● Check monitor manufacturers cable length specs - may need Tripp Lite B120-000 DVI Extender System Requirements ● Monitor with DVI, and CPU with Dual or Single Link DVI capabilities Package Includes Description Tripp Lite's 25-ft. (7.62 m) DVI Dual Link TMDS cable delivers the high performance, high bandwidth needed for todays digital video displays. Note: Review your monitor manufacturers specifications for a stated maximum DVI cable length. While many monitors only support a 5 meter (16ft) DVI cable, simply adding a Tripp Lite B120-000 DVI Extender will guarantee full digital signal strength at any length up to 150-ft. (45.72 m). Gold plated contacts ensure excellent conductivity, while double shielding (foil and braid) provides maximum EMI/RFI protection. Use in conjunction with DVI video cards that are specified as Dual or Single Link. Both DVI connectors are molded, have integral strain relief for long life reliability, and ferrite collars to drain off extraneous electrical interference. Features ● Superior molded cables with foil/braid shielding for maximum EMI/RFI ● Dual Link digital signaling for transmission speeds to 9.9Gbps and 2560 x 1600 resolution ● Meets DVI DDWG Standard ● PC and Mac compatible ● For use with Digital CRT displays, Flat Panel Displays, HDTV and Projectors ● Check monitor manufacturers cable length specs - may need Tripp Lite B120-000 DVI Extender Specifications OVERVIEW UPC Code 037332138804 Product Type Passive Cable Technology DVI Cable Type Passive 1/2 ● DVI Dual Link TMDS cable DVI-D, M/M, 25-ft. (7.62 m) 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Shipping Dimensions (hwd / in.) 12.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 25.40 x 1.27 Shipping Weight (lbs.) 1.43 Shipping Weight (kg) 0.65 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 CONNECTIONS Side A - Connector 1 DVI-D DUAL LINK (MALE) Side B - Connector 1 DVI-D DUAL LINK (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P560-025 价格&库存
很抱歉,暂时无法提供与“P560-025”相匹配的价格&库存,您可以联系我们找货
