P580-020
P580-020
    TRIPPLITE
    CABLE ASSY DISPLAYPORT W/LATCH
P580-020 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort Cable with Latching Connectors, 4K (M/M), Black, 20 ft. (6.09 m) MODEL NUMBER: P580-020 Highlights ● Digital Video and Audio in one cable ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 30Hz, including 1080p ● Small footprint compared to VGA or DVI Package Includes DisplayPort Monitor Cable - 20-ft. (6.09 m) Features ● The future standard for Digital Video and Audio connections ● Supports Displayport v1.1 ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 30Hz, including 1080p ● Monitor Resolution Support: 3840 x 2160 @ 30Hz, 2560x1600 @ 60Hz, 1920x1200 @ 120Hz ● Supports High Definition Content Protection ( HDCP ) Specifications OVERVIEW UPC Code 037332176561 Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2 Signal Transmission Bidirectional 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 20 Cable Length (m) 6.10 Ferrite Core No Minimum Bend Radius 73mm Shipping Dimensions (hwd / in.) 13.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 33.02 x 25.40 x 1.27 Shipping Weight (lbs.) 0.62 Shipping Weight (kg) 0.28 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range -40 to 158 F (-40 to 70 C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States MST Support Yes Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P580-020 价格&库存
很抱歉,暂时无法提供与“P580-020”相匹配的价格&库存,您可以联系我们找货
