P560-050
P560-050
    TRIPPLITE
    CABLE SHIELDED DVI-D M/M 50'
P560-050 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B120-000) should be used with this cable to ensure a signal strong enough for your display. An alternate solution is to use a Tripp Lite DVI over Cat5 Highlights ● For use with Dual or Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 2560 x 1600 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection Extender (Model Number: B140-101X) in place of a 50 ft. DVI cable and signal booster. Note that Tripp Lite's DVI over Cat5 Extender products support DVI Single Link resolutions only. DVI Dual Link Cable, Digital TMDS Monitor Cable (DVI-D M/M), 50 ft. (15.24 m) MODEL NUMBER: P560-050 System Requirements ● DVI monitor ● CPU with DVI Dual Link capabilities Package Includes ● Description Tripp Lite's 50-ft. (15.24 m) DVI Dual Link TMDS cable delivers the high performance, high bandwidth needed for today's digital video displays. Gold plated contacts ensure excellent conductivity, while double shielding (foil and braid) provides maximum EMI/RFI protection. Use in conjunction with DVI video cards that are specified as Dual or Single Link. Both DVI connectors are molded, have integral strain relief for long life reliability, and ferrite collars to drain off extraneous electrical interference. In most applications, a signal booster (B120-000) will need to be used with this cable to ensure a signal strong enough for your display. Features ● For use with Dual or Single Link TMDS specified equipment ● Compatible with Flat Panel Displays, Digital CRT Displays and Projectors ● Provides bandwidth for resolutions up to 2560 x 1600 ● High Speed Digital Transmission to 9.9Gbps ● Superior molded cables with foil/braid shielding for maximum EMI/RFI protection ● In most applications, a signal booster (B120-000) will need to be used with this cable to ensure a signal strong enough for your display Specifications OVERVIEW UPC Code 037332131058 Technology DVI 1/2 50-ft. (15.24 m) DVI Dual Link TMDS Cable (DVI-D M/M) 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 50 Cable Length (m) 15.24 Shipping Dimensions (hwd / in.) 17.00 x 14.00 x 1.00 Shipping Dimensions (hwd / cm) 43.18 x 35.56 x 2.54 Shipping Weight (lbs.) 4.70 Shipping Weight (kg) 2.13 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 CONNECTIONS Side A - Connector 1 DVI-D DUAL LINK (MALE) Side B - Connector 1 DVI-D DUAL LINK (MALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; EIA/ECA-310-E WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P560-050
1. 物料型号: - 型号编号:P560-050 - 这是一根50英尺(15.24米)长的DVI Dual Link TMDS电缆(DVI-D M/M)。
2. 器件简介: - 该DVI Dual Link TMDS电缆能够提供现代数字视频显示器所需的高性能和高带宽。 - 镀金接触点确保出色的导电性,双重屏蔽(箔和编织)提供最大的EMI/RFI保护。 - 与指定为双链路或单链路的DVI显卡一起使用。 - 两个DVI连接器都是模制的,具有内置的抗拉设计,以确保长期可靠的使用寿命,并且带有铁氧体颈圈以排除多余的电气干扰。
3. 引脚分配: - 端A - 连接器1:DVI-D双链路(公头) - 端B - 连接器1:DVI-D双链路(公头) - 没有锁定或紧握连接器。
4. 参数特性: - 技术:DVI - 电缆类型:被动 - 物理特性:黑色,50英尺长,15.24米长,600英寸长。 - 产品合规性:符合RoHS标准。
5. 功能详解: - 与双链路或单链路TMDS指定设备一起使用。 - 兼容平板显示器、数字CRT显示器和投影仪。 - 提供高达2560 x 1600的分辨率带宽。 - 高速数字传输至9.9Gbps。 - 在大多数应用中,需要与信号增强器(B120-000)一起使用,以确保显示器的信号足够强。
6. 应用信息: - 适用于需要高分辨率和高速数字传输的应用场合,例如数字视频显示器。
7. 封装信息: - 电缆颜色:黑色 - 电缆外径:50英尺(15.24米) - 运输尺寸:17.00x14.00x1.00英寸 - 运输重量:4.70磅(约2.13公斤)
P560-050 价格&库存
很抱歉,暂时无法提供与“P560-050”相匹配的价格&库存,您可以联系我们找货
