P569-025
P569-025
    TRIPPLITE
    P569-025
P569-025 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States High Speed HDMI Cable with Ethernet, UHD 4K, Digital Video with Audio (M/M), 25 ft. (7.62 m) MODEL NUMBER: P569-025 Highlights ● 25-ft. (7.62 m) High Speed with Ethernet HDMI cable v1.4 ● Supports transmission speeds up to 18 Gbps ● Backward compatible to previous HDMI generations ● Video mirroring with iPad2 System Requirements ● HDMI video source and HDMI enabled TV / Monitor Package Includes 25-ft. (7.62 m) High Speed with Ethernet HDMI Cable v1.4 Features ● 25-ft. (7.62 m) High Speed with Ethernet HDMI cable v1.4 ● Supports transmission speeds up to 18 Gbps ● Backward compatible to previous HDMI generations ● Fully molded cables, with Gold plated connectors assures long life ● Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the web and display presentations Specifications OVERVIEW UPC Code 037332160676 Product Type Passive Cable Technology HDMI Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 30Hz Max Supported Color Depth 48-bit Deep Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:4:4 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States EDID Support Yes Signal Transmission Bidirectional AUDIO Audio Specification ARC USER INTERFACE, ALERTS & CONTROLS LED Indicators 0 PHYSICAL Color Black Material of Construction PVC Cable Jacket Color Black Connector Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Ferrite Core No Minimum Bend Radius 36.5mm Shipping Dimensions (hwd / in.) 12.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 30.48 x 25.40 x 1.27 Shipping Weight (lbs.) 1.22 Shipping Weight (kg) 0.55 ENVIRONMENTAL Operating Temperature Range 14° to 122°F (-10° to 50°C) Storage Temperature Range 5° to 140°F (-15° to 60°C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 HDMI (MALE) Side B - Connector 1 HDMI (MALE) Connector Plating Gold Contact Plating Gold Connector Style Straight Latching or Gripping Connector No FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support No Antibacterial No IP68 Rated No IP20 Rated No Armored Cable No Ethernet Support Yes HDCP Specification 1.4; 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P569-025 价格&库存
很抱歉,暂时无法提供与“P569-025”相匹配的价格&库存,您可以联系我们找货
