P580-025
P580-025
    TRIPPLITE
    P580-025
P580-025 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort Cable with Latching Connectors, 4K (M/M), Black, 25 ft. (7.62 m) MODEL NUMBER: P580-025 Highlights ● Digital Video and Audio in one cable ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 30Hz, including 1080p ● Small footprint compared to VGA or DVI Package Includes DisplayPort Monitor Cable - 25-ft. (7.62 m) Features ● The future standard for Digital Video and Audio connections ● Supports Displayport v1.1 ● Supports Ultra High Definition (UHD) 4K x 2K video resolutions up to 3840 x 2160 @ 30Hz, including 1080p ● Monitor Resolution Support: 3840 x 2160 @ 30Hz, 2560x1600 @ 60Hz, 1920x1200 @ 120Hz ● Supports High Definition Content Protection ( HDCP ) Specifications OVERVIEW UPC Code 037332176554 Product Type Passive Cable Technology DisplayPort Cable Type Passive VIDEO Max Supported Video Resolution 3840 x 2160 (4K) @ 60Hz Max Supported Color Depth 24-bit True Color HDR Support No 3D Video Supported Yes Chroma Sub Sampling 4:2:0; 4:2:2 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Signal Transmission Bidirectional PHYSICAL Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 7.3 mm Wire Gauge (AWG) 28 Cable Length (ft.) 25 Cable Length (m) 7.62 Cable Length (in.) 300 Ferrite Core No Minimum Bend Radius 73mm Shipping Dimensions (hwd / in.) 13.00 x 10.00 x 0.50 Shipping Dimensions (hwd / cm) 33.02 x 25.40 x 1.27 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 ENVIRONMENTAL Operating Temperature Range 32° to 113°F (0° to 45°C) Storage Temperature Range -40° to 158°F (-40° to 70°C) Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes Consumer Electronics Control (CEC) Supported No CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Connector Plating Nickel Contact Plating Gold Connector Style Straight Latching or Gripping Connector Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS EMI/RFI Line Noise Protection No MST Support Yes Antibacterial No IP68 Rated No Armored Cable No Ethernet Support No Displayport Specification 1.2 HDCP Specification 2.2 STANDARDS & COMPLIANCE Product Compliance RoHS; REACH; WEEE WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P580-025 价格&库存
很抱歉,暂时无法提供与“P580-025”相匹配的价格&库存,您可以联系我们找货
