P580-100
P580-100
    TRIPPLITE
    CABLE ASSY DISPLAYPORT W/LATCH
P580-100 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States In some applications, a signal booster (Model Number: B121-000) should be used with this cable to Highlights ensure a signal strong enough for your display. ● DisplayPort Cable with Latches (M/M) 100 ft. (30.5 m) Digital Video and Audio in one cable ● Supports 1080p resolution ● Small footprint compared to VGA or DVI MODEL NUMBER: P580-100 Package Includes DisplayPort Monitor Cable - 100-ft. (30.5 m) Features ● The future standard for Digital Video and Audio connections ● Supports Displayport v1.2 ● Provides up to 1080p resolution ● Monitor Resolution Support: 2560x1600 @ 60Hz, 1920x1200 @ 120Hz ● Supports High Definition Content Protection ( HDCP ) ● In most applications, a signal booster (B121-000) should be used with this cable to ensure a signal strong enough for your display. Specifications OVERVIEW UPC Code 037332176585 Technology DisplayPort Cable Type Passive PHYSICAL Color Black Cable Jacket Color Black Cable Length (ft.) 100 Cable Length (m) 30.49 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 14.00 x 17.00 x 1.00 Shipping Dimensions (hwd / cm) 35.56 x 43.18 x 2.54 Shipping Weight (lbs.) 3.60 Shipping Weight (kg) 1.63 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DISPLAYPORT (MALE) Latching or Gripping Connector Yes FEATURES & SPECIFICATIONS IP68 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P580-100
1. 物料型号: - 型号编号:P580-100 - 信号增强器型号:B121-000(在某些应用中需要与此电缆一起使用以确保信号足够强)
2. 器件简介: - 这是一根DisplayPort电缆,带有锁扣,长度为100英尺(30.5米),支持1080p分辨率,相比VGA或DVI具有更小的占用空间。
3. 引脚分配: - 连接器A端:DISPLAYPORT(公头) - 连接器B端:DISPLAYPORT(公头) - 带有锁扣或抓握连接器:是
4. 参数特性: - 支持DisplayPort v1.2 - 提供高达1080p的分辨率 - 支持高清晰度内容保护(HDCP)
5. 功能详解: - 作为数字视频和音频连接的未来标准 - 支持2560x1600 @ 60Hz和1920x1200 @ 120Hz的显示器分辨率
6. 应用信息: - 在大多数应用中,应与型号为B121-000的信号增强器一起使用,以确保信号足够强。
7. 封装信息: - 颜色:黑色 - 电缆长度:100英尺(30.49米) - 发货尺寸:14.00x17.00x1.00英寸 - 发货重量:3.60磅(1.63千克)
P580-100 价格&库存
很抱歉,暂时无法提供与“P580-100”相匹配的价格&库存,您可以联系我们找货
