1000 Eaton Boulevard
Cleveland, OH 44122
United States
In some applications where the HDMI cable exceeds 16ft, a signal booster (B122-000-60) will need to be
Highlights
used with this cable to ensure a signal strong enough for your display.
High-Speed HDMI Cable, Digital Video with
Audio, UHD 4K (M/M), Black, 25 ft. (7.62 m)
Premium double-shielded digital
audio/video cable
Supports iPad2 Video Mirroring
when used with Apple Digital AV
Adapter
MODEL NUMBER: P568-025
Gold-plated connectors provide
optimal signal transfer
Bandwidth up to 18 Gbps - Full
1080p resolution
High Speed HDMI and HDCP
compliant
Supports High Definition (HD)
video resolutions up to 1080p
Package Includes
Description
Tripp Lite's 25-ft. (7.62 m) High Speed HDMI (High-Definition Multimedia Interface) Gold Cable allows
interconnection between digital display devices, such as DTV's (Digital Television), Plasma displays, LCD
TV's and projectors, to Digital source devices, such as Digital Set-Top boxes, Blu-Ray players and AV
receivers. Supports iPad2 Video Mirroring when used with Apple Digital AV Adapter. HDMI assures that
the best audio/video signal is always sent from the source (HDTV signal, Blu-Ray Player) to the display
(Projection Television, LCD, Plasma, etc.). It does this by allowing uncompressed video and multi-channel
audio data to be input to the display device through one single cable. An HDMI connection allows input at
high rates of speed, up to 18 Gbps.
Features
Creates a pure digital connection between HDMI-enabled HDTV display devices and HDMI-enabled
digital video sources
Gold-plated connectors provide optimal signal transfer
Premium double-shielded cable protects against outside noise (EMI/RFI)
Impedance-matched twisted-pair construction reduces cross-talk and interference
Bandwidth up to 18 Gbps - Full 1080p resolution
Perfect for connecting an iPad2 to an HDTV (video mirroring) to watch movies, play games, surf the
web and display presentations
Supports High Definition (HD) video resolutions up to 1080p
Specifications
OVERVIEW
UPC Code
037332137951
1/4
HDMI Gold Cable
Cleveland, OH 44122
United States
Product Type
Passive Cable
Technology
HDMI
Cable Type
Passive
VIDEO
Max Supported Video Resolution
3840 x 2160 (4K) @ 30Hz
Max Supported Color Depth
48-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Chroma Sub Sampling
4:4:4
EDID Support
Yes
Signal Transmission
Bidirectional
AUDIO
Audio Specification
ARC
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
PHYSICAL
Color
Black
Material of Construction
PVC
Cable Jacket Color
Black
Connector Color
Black
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
7.3 mm
Wire Gauge (AWG)
28
Cable Length (ft.)
25
Cable Length (m)
7.62
Cable Length (in.)
300
Ferrite Core
No
Minimum Bend Radius
36.5mm
Shipping Dimensions (hwd / in.)
1.00 x 7.00 x 7.00
Shipping Dimensions (hwd / cm)
2.54 x 17.78 x 17.78
Shipping Weight (lbs.)
1.23
Shipping Weight (kg)
0.56
2/4
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
EDID Compatible
Yes
Consumer Electronics Control (CEC)
Supported
Yes
CONNECTIONS
Side A - Connector 1
HDMI (MALE)
Side B - Connector 1
HDMI (MALE)
Connector Plating
Gold
Contact Plating
Gold
Connector Style
Straight
Latching or Gripping Connector
No
FEATURES & SPECIFICATIONS
EMI/RFI Line Noise Protection
No
MST Support
No
Antibacterial
No
IP68 Rated
No
IP20 Rated
No
Armored Cable
No
Ethernet Support
No
HDCP Specification
1.4; 2.2
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“P568-025”相匹配的价格&库存,您可以联系我们找货
